What PC speakers are u using?
Goodshot
Crimsoon
86technie
86technie
This edifier s351db is bluetooth only? Can connect via USB to PC?
Any signs of muddiness/bass bleed in the bass? Sound clearer than your m50w? :s13:
I only have a brief experience the sound quality is good and strong.
But still depend on your source and soundcard as I test using a ASUS ROG motherboard
with ASUS SupremeFX Audio.
Entry level motherboard may make the speaker sound weaker.
trupurple
Sold my audiophile ones.
Using Swan Os-10 Being new, I thought it would be good. But it lose miserably to even the 15yr old Creative T20.
It's so bad even my high end DAC can't save it, sounds like behind ton of bricks.
ckling
Really? Review like not bad for the price
Goodshot
Can connect via Bluetooth, RCA to 3.5( For Pc) , optical, coaxial or AUX
No muddiness/bass bleed , i feel 20% better bass / vocal than my old m50w . the cable given are thick n solid also . Cant say top notch but definitely damn good for $300 range
Alphas
My PC is always connected to Yamaha 5.1 receiver and Pioneer linear power bookshelf speakers.
86technie
I only use 5.1 speakers, for movies and games
Avoid Creative Inspire speakers.
The subwoofer tend to distort when you max out the bass.
I had this in the past really regard both 2.1 and 5.1 version.
Logitech wise no such issue the bass is strong even when you max it.
Is cheap quality of the sub thus it distort, I have open it up before.
The plywood is very thin and isn't reinforced thus causing the distortion.
Goodshot
Hmm.. take back my word after days of testing all the songs / movie I feel M50w actually sound more natural. This 351db bass n vocal crossover not that good enough.
Overall not a good buy , not recommend 😅
Crimsoon
Does anyone know of any speaker repair shop that can be recommended? My bose companion 5 is down with motherboard issue.. the sound coming out of the subwoofer is very very soft.
rarenick
U all buy so good speakers... Just wondering if u listen at high sound volume or not? If too loud will disturb neighbours. Might as well use good quality earphones/headphones?
Read HWZ Forum Rules!
86technie
Not worth the repair cost you can get a new speaker instead.
