When is Mi6 launch?
balzebub
Guys I updated the so called fake rom aka shop room thru fast boot to 8.2.2.0. After the nightmarish problems of installing the global and development rom from mi website and finding out they don't include Google play I reinstalled the fake rom which is an update from the original 8.2.0.0 I think when I first unboxed it.
The problem with the older shop rom was that it couldn't connect as a theterhing device to 3 other devices. The newer one is better but still has problems certainly didn't match up to my mi4i which provided unending internet to 3 other devices with no disconnection. Also I discover my mi6 somehow cannot connect wirelessly with my mibox. No reasons given.
Yup it's quite a disappointment to me despite the very high benchmark scores.
I installed the global stable 8.2.2.0 (NCAMIEC). It comes with Google store and all the Google services? Everything works fine.
Sent from Xiaomi MI 6 using GAGT
deckcard
Did you wipe all when installing the global ROM? It is necessary to do a clean install becos you are having weird problems. When use miflash, choose the option to flash_all and it will all including data and internal storage. Do a backup of ur data first, copy to ur PC first tho so you can copy/ restore them later
cscs3
【小米6还未发布之时,就已被寄予厚望,雷军的饥饿营销也制造了小米6一机难求的景象,然而,抢到米6的小伙伴,这下可要泪奔了!因为米6自身问题不断,引发众人吐槽!出现的问题:充电重启、手机屏幕漏光,wifi断流、缝隙大,NFC公交卡关闭,手机部分场景下发热较大。仅仅上市3天,小米6就被】,点击链接再选择浏览器打开http://c.b1yt.com/h.Q3Ydox?cv=OaUtZCKeSKZ&sm=240a1f ,或复制这条信息¥OaUtZCKeSKZ¥后打开👉手机淘宝👈
Anyone encounter the bugs mention ?
redname
As much as I can understand the paragraph, I haven't met those bugs
ZeusTheMighty
You mean the clean all option?
Nope i didn't do that.
jeff79
The charging reboot, nfc sim resolved already. Back panel gap is due to first xiaomi phone to use water resistant adhesive tape instead of snap clips. Did not noticed wifi disconnect or thoroughly search for backlight leak. While charging and running benchmark max temperature is around 43 degrees. Not very hot and concentrated at one corner
balzebub
【小米6还未发布之时,就已被寄予厚望,雷军的饥饿营销也制造了小米6一机难求的景象,然而,抢到米6的小伙伴,这下可要泪奔了!因为米6自身问题不断,引发众人吐槽!出现的问题:充电重启、手机屏幕漏光,wifi断流、缝隙大,NFC公交卡关闭,手机部分场景下发热较大。仅仅上市3天,小米6就被】,点击链接再选择浏览器打开http://c.b1yt.com/h.Q3Ydox?cv=OaUtZCKeSKZ&sm=240a1f ,或复制这条信息¥OaUtZCKeSKZ¥后打开�手机淘宝�
Using for more than a month, no gaps, no light leakage, no WiFi issue, no reset while charging, NFC works fine. Yes it does get hot when charging especially if u use the phone while plugged in to charger. Think by now most of the bugs have been resolved?
ZeusTheMighty
Here are some pics taken with the mi 6 a bit of editing with lightroom to adjust the proper ratios and straighten some pics. Some are HDR some non HDR
What do you think of them?
happybaby
any one managed to get android pay to work in global stable 8.2.2.0?
i can't get it to work at giant yesterday. my app installed and verified. pass safety net app check also.
