Brandedclassicwear
- Nov 1, 2024
Are you looking for European fabrics or cheap asian fabrics like wool blend?Any tailor recommendations for Da nang or Hoi An?
Do you have time and budget for a high quality suit or you just want a cheap suit that fits well?
If you place quality first, there is only one tailor in Danang and only one tailor in Hoi An , the rest all cmi.
If you place budget first, there is one with low price and reasonable value quality.
If you place time first, go Hoi An, they hold the world record for shortest time needed to make a suit
If you are newbie , suggest you place quality first because a higher priced suit can still be value for money in these places whereas a lower price suit can chop you carrot and still make money out of you, even though it's low in price.
