Whitestone Dome Screen Protector Problems..
Aikon
Just replaced my whitestone at redwhite due to top bubble and popping out slightly. my fp i disabled due to totally cant register.
now this new piece, can use fp just like the original film protector. good news for me. depends on luck
I thought they have no stock? I went down this afternoon they said don't know when the stock for S10 Plus will come in.
dappercivility
New stock coming in tomorrow. mine was a reserved piece, i reserved 2 pieces as i had read of all these issues in case i needed a spare
cstanhwz
You all do know that if you all cure it, you all could actually remove it and re apply right?
Just that you need a lot of patience to save it. You will need isopropyl alcohol which can be bought in guardian, soak it and leave it there for abt half an hour. Then use a cotton ball or best lint free cloth to rub off the gel like loca.
Oh, that's how to do it? I was trying to rub off using my fingers. Nearly get blisters...in the end throw it away as very tulan. :s13:
wow it says press down the fingerprint area for 1 min after the first cure. Before doing 2nd cure. :s22:
so is that the missing key part?
Suspect is due to too much or uneven LOCA at the sensor area. So after 1st cure of 15s, press the sensor area to reduce the LOCA then cure again.
royfrosty
Lol. Yeah, but you must live with 1 drawback. And that is the oleo coating will reduce a little bit. Since using alcohol to soak. But overall still can be reuse.
cstanhwz
I see...:)
But I think I will not make the same mistake again lah. S$60 lesson well learnt!!! :s13:
bratpig
I was successfully initially
But I grew impatient and used sponge to rub off the residual.
End up the screen got scratches. Lol. Outside is scratch resistant but apparently not inside
Sent from Samsung SM-N960F using GAGT
dappercivility
just noticed a crack across the screen on my s10 plus, the whitestone tempered glass cracked. my note 9 use a few days whitestone also cracked. 2nd piece i use the cheaper loca china tempered glass. no issue at all.
will wait for the china loca tempered glass to be available since i do not use the fp anyway.
Glariel
Own self crack or u drop it?
My S8, S8+ Note8, S9, S9+ and Nofs9 all got Whitestone no crack leh
dappercivility
never drop, inside pocket all the time but pocket abit tight. maybe sitting down bend pressure cracked the glass. i only can afford old nokia for my other phone. you are rich man so many high end phones i can only dream to own
Glariel
Whitestone was never meant to be put in pocket. Especially when you put in pocket the dust stick around the screen protector, if clean not careful then gone already
athenodorus
What? Not meant to put in pocket? Lololololololol.
Should put inside Ziplock bag since everywhere also got dust not just pocket.
cstanhwz
I usually use the LED cover on my phone and put in front pants/jeans pocket.
If dust get trap on the edge of the WSD, just use a slightly moist cloth (used to wipe spectacle) to wipe. Most of the dust should go away and the LOCA at the edge should not be easily scrape away.
Sidler
Right?? I stun when I saw his reply too...
Yeah, ziploc bag best for him. Wireless charge, don't take out, won't kena dust.
shadow84
Maybe best to hang over his neck like pri sch kid. Like that, got better chance for his hands to protect it when needed.
I put my s8 in my pocket for 2 yrs, not a single crack. Except one time when i accidentally put torchlight in pocket as well and squat down during work.
Zijin_
true also hang over neck wont tio kope also.. if not put pocket later people kope sia quite dangerous
royfrosty
I never put phones in pocket to prevent radiation
Rofl. You really believe phone radiation harm you lah?
If thats the case, please stop using phone. Cause the signal that you are getting through your phone is radiation through the air and is a lot more stronger than your phone.
KeYoKe
even if never use also got radiation everywhere because everyone around u is using phone :s13::s13::s13:
zhaohan
radiation is kinda hard to avoid nowadays, there are phones, antennas, routers everywhere
