I hve checked w samsung support. They said Whitestone not approved by Samsung. I hve similar problem n installed Whitestone n it didn't work. I used sp but the original sp came w Samsung came out after a few days. Samsung can't help. So too bad
Rofl. You really believe phone radiation harm you lah?
Guys, please let me know what you think.
WSD, installed at MobileStop.
First piece - whole of top part have defect (dunno how to describe, fine bubbles?).
Second piece - only top left part have defect.
MobileStop kind enough to offer one last installation for me. BUT I don't wish for the same thing to happen. They mentioned I may want to consider changing a case and WSD recommend 0.7mm gap all around.
Case in use: UAG Monarch
Anyone S10+ UAG Mornarch + WSD without any problem?Looking at the pictures, what do you think? Is it a problem with the installation method? (ie: installer) If so, I may want to consider going to another outlet.
FIRST PIECE
SECOND PIECE
I never put phones in pocket to prevent radiation
just use film based protector with spigen ultra hybrid is safe enuff.. tempered glass waste of time..
- Anyone S10+ UAG Mornarch + WSD without any problem?
- Looking at the pictures, what do you think? Is it a problem with the installation method? (ie: installer) If so, I may want to consider going to another outlet.
FIRST PIECE
SECOND PIECE
Get a tempered glass sp (Loca glue) finger in right position 9/10 successful
Sent from HUAWEI EVR-L29 using GAGT
Guys just got my zeelot loca tempered glass. It does not have the cutout for the camera. And fingerprint is working right from the start! Just a light tap. Casefactorie has it. Recommended to buy it online first to reserve your glass
Please only recommend after using a period of time. After that can also share on other info like oleophobic coating strong anot etc.
Mean the glass and glue cover the camera? Camera quality affected?
Remember earlier post someone warn about tempered glass protector for rear camera, got reflection or something like that.
