Whitestone Dome Screen Protector Problems..
NeonX
Naked is best feeling
Removed my TGP (non Whitestone). The feeling is its a phone like never before.
Decided on this move as I guess there will never be a screen protector regardless of type and brand that will be like having a nude screen.
Touch wood, if anything really happens to the screen, it might still be cheaper than the money I spend on the various SP or TGPs.
Glariel
If you take care and never drop your phone like me then you can go naked.
All my phones I owned, never drop before. But they have screen protector on.
My previous 2 years flagship I owned, all are using Whitestone tempered glass and the case I using Samsung clear view cover as I don’t want to risk the glass being lifted up
tutonic
Anyone know of any film screen protectors that have good oleophobic coating? My TGSP got a bit of air bubble since I was overseas recently; think the air pressure difference when flying caused it.
Glariel
Not that I know off.
Curved screens best to use Whitestone or those with loca glue
KeYoKe
u can take a look at the ringke one at lazada, but u need to self apply though :s13:
wwh5210
Don't bother trying UV glass type anymore coz the end result will be the same no matter which brand u choose. The main problem is the ultrasonic sensor. It detects and verifies our fingerprints via ultrasonic wave and ultrasonic wave is very sensitive to it's medium thickness.
Ultrasonic sensor >> OLED >> Glass surface >> UV Glue >> Glass Protector.
That's the tech limit for now.
bratpig
My hand smooth smooth white white. It's difficult not to drop anything
Sent from Samsung SM-G975F using GAGT
jtec14
Interested in getting one to try. Is this the same shop? https://world.taobao.com/item/558970564785.htm
I bought this for my wife s10+, quality is good and his video have steps specifically for the fingerprint, unfortunately i may have screwed up thus fingerprint scan I felt that it is still not sensitive enough.
If u read the reviews, some post the videos and the scanning seems work fine.
Glariel
That’s why I never bother to use Whitestone for my s10 series
