Ye_Rongtian
- Dec 4, 2000
Mine installed on Sat. During registering fingerprint need to press down a bit. After that to unlock just need a tap. Touch sensitivity not turned on.
Just an update. The first batch of wsd, bought it through a friend whom gotten it from p2o mobile. It works well and gets better day by day.
The mobilestop/wsd official/qoo10 seller, did not send to me till they cancel my order and told me that the fp scanner may not work.
A refund was given to me. I insist on buying another piece as spare. So i acknowledge the issue and re bought it. It never came till a week later. When questioned or asked, they said that they have ran out of stocks.
The shipment shipped out on Monday, arrived on Wednesday. I was reluctant to open it. But once i opened it i found out it was the revision model.
This 2nd revision is slightly different from the 1st.
- 2 sets of micro dots are at the far sides of the glass.
- glue supplied seems lesser
- revised tray insert
- uv come together as a set. Not 1 box uv 1 box content
- instructions changed to the new one as per their youtube video.
So i removed my existing one and removed the loca glue. Keep it back in box and try the new rev.
The new one works even better than the previous at start.
BUT.... suay me, my ezlink in bag accidentally sliced and lift through my wsd. Went back home remove the loca glue again and reapply. Lol
Day 1 after 12hrs of application. Fp scanner works well. Will update again tomorrow.
I can't find any information on this revision model of the WSD. Any link you can provide? Thanks
I do not have any link. But if you buy the first rev, you will notice it is a different package and glass slightly differs.
Not sure if you can see 2 micro dots at the sides. It is found on both side of the glass.
Thanks. Do you know what the 2 micro dots purpose is? The first gen WSD on my S10 is so bad...like it has a mind of its own deciding when it will let my fingerprint be read, and when i'm in a rush to unlock my phone it will never be read![]()
Installed zeelot tempered glass at causewsypoint. After install, i totally can't register my fingerprint at all. After an hour or so, i can register my fingerprint lightly. Unlock rate getting better slowly. Will monitor see
Hoq much was it?
this zeelot is weird, maybe is my phone weird. i said it work last night, after i bath, it totally dun work again. and this morning it work but not very good. now maybe work like 7/10 times.
I find that the fingerprint sensor doesn't work well when my fingers are over-moisturised, e.g. after a bath. Once they dry off it works just as usual. That could be the fingerprint sensor itself, instead of whether a SP is on or not.this zeelot is weird, maybe is my phone weird. i said it work last night, after i bath, it totally dun work again. and this morning it work but not very good. now maybe work like 7/10 times.
