Whitestone Dome Screen Protector Problems..
aztech44
Samsung one gonna be costly and not worth unless they provide installation.
I am using nanotech film protector now from qoo10 and it's working well and very smooth to touch. Cost $5.90 with shipping.
Installation slightly tricky but still ok.
Can SIC?
10char
KeYoKe
I find that the fingerprint sensor doesn't work well when my fingers are over-moisturised, e.g. after a bath. Once they dry off it works just as usual. That could be the fingerprint sensor itself, instead of whether a SP is on or not.
Day #6 and the Zeelot one is still working well for me.
Tried on friend one. Unlock is indeed faster then wsd
aztech44
Anyway, just to share that earlier today, i went tampines mall to get s10 tempered glass installed, saw the shop offering zeelot brand and i double check with him if in screen works fine. He said hes awared that WSD doesnt and ensure me that he pasted few other s10 owners.
He UV my phone approx 20 mins.
And once done came to suprised the in screen works fine. I dont have to press harder , just a light touch will unlock my phone. Except when register have to press harder la. Cost me $39.90
Posted from PCWX using SM-G973F
shadlightsg
Which shop in tamp mall?
Sent from Samsung SM-G975F using GAGT
tutonic
Is it Namh Co on 3rd floor?
aztech44
Yes correct. Beside oppo. Before pasting there. Do confirm with them again to ensure if they said the same thing .
*no affliation with them nor thier im thier staff*
KYLee
This zeelot screen protector does not have a camera cut out right? does it affect the selfie image quality in anyway?
aztech44
it covered the punch hole not cut out . so far so good. no issue with selfie.
shadlightsg
Just installed the zeelot tg. Still need time to adjust as a lot of misses too
aztech44
Guys check out okonz at carouselltoo, plenty of good reviews on thier TP
nexusscion
Actually both zeelot and wds wont be good at finger print no matter what brand as long there is a glass or thickness on top of the screen. Want the best finger print, stay with your default stick on screen protector or go naked
tutonic
Please don't spread mis-information. Samsung preempted the need for extra sensitivity, which is why they added the touch sensitivity setting for when you have the glass screen protector on. All this skepticism about the usability of the glass screen protector is just overshadowed by WSD's aggressive advertisement about being the only compatible screen protector, and then fail abysmally at delivering it.
And all this is coming from someone who bought WSD, then have it fail on me, and then got my refund.
where do they operate? do they have a shop? I'm looking for one that could do installation for me...
I'm also seeing if this okonz has a physical shop. I've already messaged them on FB. Will update here if I hear anything.
renfred89
Touch sensitivity option is actually intended for use with gloves, and that modifies the electrical values of the capacitive touch screen.
As for the ultrasonic fingerprint sensor, I'm not too sure if the above option modifies the electrical value of it, which I doubt so. Cos you can't scan with gloves anyway.
cheryl81
with my zeelot, touch sensitivity off and on like no difference. it work very good off too. ultrasonic finger sensor, i also see no better when sensitivity is on. it still work 50% :(
