Charlie_Zhan
- Nov 17, 2013
if you press or push on the tgsp before curing it. it will just cause bubbles to form and most likely need to remove the Loca and use another tube. you say you've came to a conclusion that UV glass just don't work for S10.. based on? personal experience trying all the different levels of Loca viscosity and type of tgsp?I've came to a conclusion that UV glass just dont work for s10, no matter what you choose. Some may have fingerprint working but at an expense of a lower quality glue which doesnt provide the optimum shatter protection of its equivalent counterpart.
Whitestone has provided slightly more volume of glue which somehow affected the thickness of the gap between glass and screen. To circumvent this, its recommended to push out the excessive glue by pressing on the glass before curing. However due to the fact that loca shrinks about 1-2% of its surface area, it causes bubble when it shrinks.
Whereas a tpu protector is more cost effective, easier to apply and is totally compatible with fingerprint scanner. I have chosen the latter..
