wwh5210
- Mar 6, 2008
I only worry when it is time to remove the sp, the glue stains hard to remove like some people previously mention![]()
Buy from AliExpress at $5... Got my own UV light.. Finger scanner works.. Follow sgfreshidea method..
All branded SP comes from China.. For sure will babe copycat... Use the same loca glue and glass..
I cheapo and not willing to pay premium when I can get way cheaper..
Bought for this link... Disclaimer mine working fine... If yours can't work probably method wrong...
SG$ 3.92 51%OFF | 2019 New S10 screen protector UV liquid full glue S10 Plus glass 6D for Samsung S10e S8 9 Note 8 9 S7 6 edge plus tempered glass
https://s.click.aliexpress.com/e/cYYCrE4C
Sent from Samsung SM-G973F using GAGT
how was it? the reviews seem positive.
Finally gave my Taobao screen protector a try and surprisingly it really WORKS. Fingerprint is in full working condition after applying the protector. I dun really have high hope for this protector from Taobao initially. Just following this guide on YouTube: https://youtu.be/r_wT8uLly0s. Please take note that I did not buy the protector from them but just following their steps.how was it? the reviews seem positive.
One thing to take note, I used a small piece of blutack to seal off my top speaker to prevent any LOCA glue flowing in.
Yes, using their LOCA glue. They are mostly the same as they all came from China lol.using their loca glue???
Loca glue got different grading one, not all the same. You use the wrong one, then gg.
decided to try zeelot again. this time i went to casefactorie.
but wow, i could use the fp right away, dont even need to re-register.
probably is the skill of the person who paste it.
since last night, it has been a breeze. will monitor and see.
the main difference is the viscosity rating.. there are some blacksheeps on AliExpress or taobao who would indiscriminately supply Loca glue with viscosity that is not suitable for temporary applications like TGSP..Not really sure about the grading and I dun think any seller will indicate grading when u buy as a set. So far so good on my set now.
fyi those thin Loca are used by 3rd party repair shops or experienced individuals for attaching just the glass cover of phones screen like the S7 edge in cases where the glass breaks but digitiser below it is still working. it's meant to be a permanent solution not temporary.
those good ones would appear slightly runny, takes about 1-2 mins to fully spread across the whole screen itself once the glass is placed on the screen. it should adhere well, not lose touch sensitivity and provide a certain degree of resistance against lifting.
if you suay and kena one that is too thick, it will take forever to spread across the screen during application, easy to lift/shift/misalign even after curing, frequent and heavy accumulation of dust/dirt around the edge of the glass and in no time your constant cleaning and wiping to clear those dirt will rub off part of the cured Loca and accelerate the time for lifting and bubbles to appear at the edges. to put it short, it's like pasting the sp to the screen using transparent version of bluetack.
and in the worse case scenario.......
the seller gives you Loca glue that is too thin and not meant to be used for pasting screen protectors. it's really the worse because everything may appear fine and dandy and by the time you realised you're fked, the seller maybe already close shop and retire in some casino somewhere in Macau already..
Loca glue that are too thin will appear only very slightly thicker to that of normal water and application process. you will not be able to tell that it is too thin and may even be happy that the application is much faster as it spread rather quickly. then you would even convince yourself and introduce others that you have found a gem because your SP can defeat every single protective cases out there against lifting and you don't even remember when was the last time you had to clean dirt and dust along the edges of the sp.
sht would then literally hit the fence when you drop your phone and the shatter the sp. and just when you start to tell yourself lucky for this sp and proceed to try and pry away the sp away from your phone and install a new one, you realised it's impossible to do so..
this is when you can have fun slowly scrapping away the hundreds or thousands little pieces of glass fragments that just refuses to budge.fyi those thin Loca are used by 3rd party repair shops or experienced individuals for attaching just the glass cover of phones screen like the S7 edge in cases where the glass breaks but digitiser below it is still working. it's meant to be a permanent solution not temporary.
so please practice your own due diligence before happily sorting your AliExpress or taobao search results using "price from loweest to highest" option.
no idea.. but I only trust one Tiong seller on taobao for his UV sp.. because he will constantly improve and reformulate the Loca that he includes for his kit.. from the smell alone you will know it's not the same because the one from his shop is very faint when compared to those use by others.Interesting. Any idea what kind of glue Zeelot uses?
