Alexz_Hong
hello, just wanted to know if the mpow t5 users have taken the pair for running. how's it? does the earbuds drop off easily or something?
I used it for jogging while I was using it. Doesn't fall out for me, but it does loosen a little. So it doesn't seal up well, meaning less bass, and you hear a bit more of the surrounding. but also means you hear less thumping sound from your own footsteps.
DigDub
Has anyone tried this. Seeing reviewers comparing this to the sennheisser momentum true wireless. With better bass and battery life? :eek:
The sound is quite bright. Not much mid bass. Quite ok if you are after that kind of sound.
happily1986
I use the te-d01g for running, it feels like it will drop out, but never once it did. The te-d01g, tevi and the t5 uses the same oem housing.
Thanks guys for your feedback! :)
justln
Heard from friend that Jaben OOS. :eek:
I bought one to try out, see how well it works.:)
ksksksks
Will have to test it. Quite like the sennheisser momentum tw atm but the downside is really the battery. Just gotta remind myself to put it back into the case and charge the case almost once every 2 days
DavidPeel
Good... there are MPOW T5 users here!
Recently got the M5 which is the re-labelled T5. While it sounds good, it keeps dropping signals when I go for walks. No other wifi or BT users in sight but movements cause the most dropped signals.
All I did is putting my Note 9 in my pants pocket. I change from left pocket to right pocket and it improves, less dropped signals. Taking the phone out and hold in my hand improves that even further. However sudden motions such as turning my head etc can cause dropped signals but not all the time.
Anyone faces same issues?
DigDub
My t5 has pretty strong signal.
ParkJinYoung
None of such issues
Sent from Google PIXEL 2 XL using GAGT
Haman
With my Mpow T5/M5, I had more signal drop when I went to Courts Megastore, level 3, upon stepping into the Apple counter and beyond the whole floor except Subway. When I was at Ikea Tampines, no such drop encountered that is annoying.
ApPle5
Sorry if this was asked before but anyone used Sudio before? Is it any good?
Sent from 我是你的小呀小苹果。 using GAGT
DigDub
Boomy bass that lacks definition and control. Not worth it.
ApPle5
Great, thanks for the feedback! Keep seeing their ads but never see any reviews.
edixian
Just received my Jaybird Vista in mineral blue. Yet to open as cannot decide to keep or let go :(
