ApPle5
Just received my Jaybird Vista in mineral blue. Yet to open as cannot decide to keep or let go :(
Why? Just use lah, I see reviews like not bad?
Sent from 我是你的小呀小苹果。 using GAGT
edixian
When buying, tot that i wil use it in ofc and otw work. But b4 item reach me, i got a spare cheap earbud and i jus throw in my bag and hardly use it.
tohchr
Love to hear your review :D
Before I hoot one :s13:
As what digdub said b4, the sound is really bright. The volume can be adjusted to very loud, the loudest which I ever own for tws. The mid bass is not as strong as for example jbl reflex flow. Battery life yet to test out. Overall just now listening over an hour, they was no distortions at all. I experienced occasional split seconds distortion on my jbl reflect flow in an hour of music. So, the connection on this tevi so far, I'm very satisfied. Its fast to connect when I removed it from the charging case.
magnus
seems not bad.
https://www.soundcore.com/products/variant/liberty-2-pro/A3909011
ksksksks
Thanks bro. I’m seeing it on Lazada for 149
tohchr
If u can get cheaper than 129, then buy it from lazada. Else, consider getting from jaben. Just get it without free gift. I'm enjoying this due to the bright sound.. Really a class of it own, connections is very stable after playing non stop for couple of hours.
ApPle5
Ohh then yah, maybe you wanna sell it.
