alphaone
Good lobang on Lazada for Lypertek Tevi!
$99 by Jaben. Can stack w DBS Live Fresh $12 off $80. Just bought one! :)
tohchr
Airpods pro the connection is super strong, the best I've used of any TWS earbuds so far. It also combines the left and right channels into one earbud if only one earbud is used.
Jimmy reviews also stated the connection is 100% coverage for his whole apartment. I experienced good connections too.
DigDub
Ya, maybe that's why the battery life is only average since they turned up the transmission power.
eyz
triple tap your right earbud, double "du" sound means it's activated, and triple "du" means it's deactivated.
how to activate the game mode? by app? bought this for my wife, so haven't got to play around with it much.. but on first listen, pretty amazed by what $35 can get you in terms sounds quality of TWS.
rambell
Lypertek Tevi got support bluetooth EDR or just BLE only? I looking for buds to work on ipod with bt 2.1 edr. Not sure if compatible...
chesterqw
That is some old iPod if using Bluetooth 2.1.
Newer bluetooth specifications should be backward compatible with older ones. So it should work, but don't quote me and go try at jaben instead
chesterqw
What tws earbuds have you tested the connection with?
DigDub
Tested with which phone?
The airpod pros lack volume control and not as good sq sadly. But it has ipx5 rating for just in case
Sony Xperia 5.
Ya, it lacks volume control, SQ also not the top. I believe the adaptive EQ is screwing up the sound, sometimes the audio sound full sometimes it sounds flat. Apple gotta let users be able to disable the adaptive EQ.
bojo387
Are the Apple Airpods 2 worth it at $191? HN has a Black Friday sale online for it at the moment. Planning to give as a gift to an iPhone user so was thinking of going with these.
RocketBunny
Nope. Lowest was 160+ on q10 if you not in rush
chesterqw
Sony Xperia 5.
Oooo interesting, the auto mono works on Android too eh?
That is nice
