ksksksks
Is bang for bucks for that price.
If ur existing buds Low battery can just take one out. :D
rainbow99
Have ordered both mpow t5 and lypertek tevi over the weekend. If price is not a big consideration, which should I keep to use? Or just keep both?
Mainly to listen to pop songs and prefer that calls are clear using the earbuds.
Sent from M20X using GAGT
DigDub
lypertek and mpow t5 has the exact size and case is it lol
The physical dimensions of the buds and cases are the same. They can even charge in each other's case. The difference is tevi case uses usb-c port while mpow uses micro-usb port.
DigDub
Other then some cosmetic differences they do look similar.
Does the mpow t5 have the truewireless stereo plus?
MPow t5 got true wireless stereo plus. But not all phones implement it. For eg, my Samsung s10e and note 10 connects to them in master-slave configuration, while my Xperia 5 connects in True Wireless Stereo Plus mode.
EmPtYsOuLz
Has anyone tried the Jaybird Vistas?
Been looking for a TWS for running (regular tws that don't have the fins tend to fallout for long runs) and these look like highly recommend though a little pricey
angeline23
saw some wireless earpiece collection on ezbuy... Quite a big collection, they have the cheap no brand kinds and also the premium types like JBL, Audio technica etc. The cheapest i saw was $5+ and it looks like a replica of Apple Airpods. Skeptical about the quality but good to buy and use as a gift i guess.
gong318
I ordered both on the weekends too, waiting for them to arrive and see which I prefer. lazada 's return process is very easy so I'll just return whichever I dun prefer :)
Sent from OnePlus GM1910 using GAGT
chesterqw
Is not phone only, also need the SOC.
Need minimum Snapdragon 845.
Seems like Qualcomm exclusive functionality
DigDub
Yes, the phone need snapdragon 845 and above. But I suspect there is some other standards that supports both buds direct connection to the phone also. For eg, Sony wf-1000mx3 and airpods pro I don't think they use the Qualcomm True wireless plus chip, but they are able to connect the both buds to the phone directly.
