ksksksks
Their foam tip quite solid one leh. Not easily breakable like truly fit grip
is it me or using the tevi's included foam tips makes the ear itchy? I clean my ears everyday but still itchy when using the foam tips :s13: Also, one foamtip broke off :(
daniel_83
Yes. Any challengers ba
you actually can get $10 off if you pre-order on hachi
for me i'm using shop vouchers so glad to know i can pre-order at shop
but then maybe lazy to go collect the lame $20 starbucks
DigDub
Tevi got a beta app to tune the sound. Anyone got the apk file?
Just got my Tevi.. Hmm like what some have mentioned here, bass isn't Tevi's strong point haha.
Still having some trouble finding the right fit ><
All the buds give a 'blocked ears' feeling.
hpv500
bass is there, not overwhelming but sufficient enough to bring the ambience
Sent from Note 8 using GAGT
kazuki666
Hey guys. Is there any physical store in town area which can test out Sabbat e12 ultra?
Sent from Xiaomi POCOPHONE F1 using GAGT
Windowlover
I didn’t noticed any hiss on my set tho.
I think someone here returned the set to anker because of this. Was it u :s13:
Preordered my set with challenger
Anyone have connect with Iphone 11 pro ? Mind to share this experience for calls and music etc.. plan to get one instead of Airpod Pro.:s22:
ksksksks
Think sabbat now all go up to $99? Only few sellers haven’t changed price. Wanted get a pair for Xmas exchange.
chesterqw
Seems like the Amazon reviews on the Aviot BD21f faulty charging case are true. The charging case cannot charge my right earbud already. Hope can get replacement. :(
Does it have those waterproof coating?
In that case you could try what I did for my creative outlier, using toothpicks to rub the contacts on both the case and earbuds to remove the coating.
chesterqw
But why?
The airpod pro will definitely be a better match, and you get all the benefits of the apple chip.
limz777
this non boosted bass soundstage is actually a prefer sound for some audiophile, being a basshead myself , took me a week to get used to it , i like the separation and clarity thou , you tested on flac file on poweramp ?
DigDub
I tried cleaning the contact pins still the same. Anyway I've done an exchange.
