ichinisan
Just went down to Challenger and tried out 75t.
What I like:
- Very comfortable to wear. Earbuds are small and light.
- Sleek looking (I like the shape and the colour).
- Strong bass (a bit too strong to my like lol).
- Light and compact charging case.
- USB C charging.
- Jabra App for tuning and future FW upgrade.
- IP55 rating
What I don't like:
- No wireless charging.
- Only 3 sets of eartips.
- Price is on the high side.
- NO Aptx codec.
Which outlet did you try it at?
chesterqw
Yes, it might happen as well.
If you apple phone, airpod pro ez no need think
Else, either try the freebuds 3, or something from jabra.
If you buy only to talk, consider those 1 side only from jabra
Jun Jun
So I went to the service center and tried another 2 sets of their "new batches" but it seems like the white noise is still there. Finger-crossed waiting for their next batch which is after 12th jan to arrive. See how till then...
DigDub
After using the Aviot BD21f for a few weeks, sound is good with a few reservations. Firstly the top end sounds a tad grainy. Second is the vocals sounds a tad metallic, I think it's a result of using balanced armature driver for mids. Listening to my melomania 1 again and is still impressed how natural and liquid the mids sound.
wwh5210
This item has 15 days return if purchased on lazada, even for change of mind reason. But you have to return everything in its entirety and original condition, meaning stuff like warranty card, user manual, ear tips have to be returned and the box as best as possible not damaged in anyway. Of cos lazada will then check the condition of the returned item and decide whether to issue a refund. If lazada for whatever reason deemed item is not in good condition for refund, they will send it back to you again. So not 100% guaranteed they will issue a refund but no harm trying since it doesnt cost us anything other than time wasted.
Lazada has approved my refund. Thank you once again for the help!!
Anything_Whatever
You don’t suspect.... it could be your device and not the earbuds?
Why not try with other player/device.... just to be sure....
wwh5210
Wow you got your refund so fast? When did ninja van pickup the item from you? Mine is apparently still in transit to lazada warehouse.
I dropped it at SppedPost myself. I didn't know it will be so fast too. Maybe I am not the only one who has problems with this product.
Jun Jun
Btw, does l2p support tws+? I can't get the l2p to connect as two separate tws+ mode on my mi 9t pro🤔
kazuki666
https://www.scarbir.com/tws/ssk-bt03-review
Anyone used this SSK BT03 before? Reviews seem not bad in this website, but other than that it's seem pretty unknown elsewhere...
Sent from Xiaomi POCOPHONE F1 using GAGT
pylpoh
I got sabbat e12 ultra . I think sound same as my $15 dollar awei. In fact I like th awei wireless more; better connectivity, and won't drop off ear that easily. Use awei for 1year plus, still working. Use E12 for 1 month ( a few times only), now right side dead. I read online they say e12 ultra bass is strong , I dunno what they smoking.
Actually I was looking at mpow T5 and sabbat e12 ultra too. How do these two compare do u know? I need something for metal / rock music, not much pop songs.
You take out within 5 minutes because of?
kazuki666
Hmm which makes me wonder why so much hype of e12 ultra. I am also using awei actually, T10C. Honestly I am impressed by its connectivity and volume control which some don't have. If I want to find fault, will be the sound quality isn't good for rock / heavy metal which I listen to often. Btw, amazed it can wireless charge too.
keemmeng
Can anyone advise for the Sony Headphone App, should I toggle the Ambient Sound Control on or off if I want to activate the noise cancellation mode?
I can't figure out as my ears can't really discern the difference
Thanks
Sent from Google PIXEL 3A using GAGT
Pepperisk
Thanks
Leave it as it is. Noise cancelling is already active.
Anything_Whatever
Thanks
Even though it set to ‘ON’ you have to slide the control bar to mid point to be able to hear any difference.
Eshuon
I recommend this site for review before here but nobody care
sKeLeToN
Has anyone had experience with the new Mifo 07 with dual balanced armature yet?
Wonder how does it stack up against the competition....
