kazuki666
I recommend this site for review before here but nobody care
I see this website does review less popular brands which are not even available here. From your experience, their reviews are legit?
Sent from Xiaomi POCOPHONE F1 using GAGT
grays0n
Anyone knows where can i get eartips size XL or 14mm
I tried afew places but most do not carry them,. Max size is usually only L, which is 13mm.
DigDub
https://www.scarbir.com/tws/ssk-bt03-review
Anyone used this SSK BT03 before? Reviews seem not bad in this website, but other than that it's seem pretty unknown elsewhere...
Local got sell something similar. Monster Clarity HD Airlinks.
Sound quality is very good. Cons is only left side can use when in mono mode and the buttons are a bit stiff to press.
Eshuon
I see other people using this website review on reddit and he also reviewed over 50 pairs of true wireless earphones so it's pretty creditable. though cross reference with another reviewer is always better. I suggest this site https://crinacle.com/guide/tws/ author is someone who reviewed over 700 mostly wired iems and he's also from SG if that matters lol
ParkJinYoung
Looks good leh cos I'm using Mpow T5 now
Maybe will consider this
Sent from Google PIXEL 2 XL using GAGT
kazuki666
Bite the bullet last night, just whack don't think haha. Only downside is it seems to be brandless OEM...
FatalityV
my BT03 kena stuck on steero mode, anyone knows how to reset? LOL
ninakan
Go eat mala wait until your burning inside... shove the buds inside your but-t and s-hit aall that diarhoeea along with ur buds in the toilet and flush it... it will work
DigDub
Nice MW07 Go. Welcome to the M&D family. IPX6 rating! Fit wings shiok right. Super secure, gives u that sense of security that it will never ever drop out of ur ears.
I removed the wings cos they block my ears. Mine came with 2 left wings for the large size, think m&d made a mistake in the packaging. Sound is bright and sibilant, had to eq and use spinfit cp100z tips to tame the sibilance and highs.
maumu
m&d got EQ app meh?
