Nakedtoes
Been using this as my daily drivers since receiving them. Only issue is the ON/OFF of the ANC and ambient listening mode. Hope the next OTA can do something abt it..
does the 1more ANC got support APTC HD?? now selling 22x thinking worth or not
lenseview
Klipsch T5 soc is able to support but its not enabled.
The newer series from klipsch which is available in a few months will be with aptx hd.
Nakedtoes
thx for the info... AAC to aptx not much different.. but aptx vs aptx hd lots of different
lenseview
Ya. Can support 24 bit flac. But too bad for me. Samsung still doesnt support aptx hd. See the S and note series released this year will be able to support or not. Flagship phone without aptx support is :s13:
Eileen007
I have a budget of $200. Any recommendations for true wireless i can get at that budget? Android user btw.
Anything_Whatever
With that kind of Budget, better to go brick n mortar shops (Stereo, Connect IT, Challenger etc) to try out demo.... see which one fits you.
Some may say ... this one good... that one good.... you may end up disappointed if eventually it doesn’t sound that great or the fit is uncomfortable....
SwaKu
Hi, anyone have both MPOW T5 and FIIL T1X? Can share how the FIIL compare against the T5. I got the T5 recently and it sounded really good but I wished the highs has a bit more sparkle. But for the price, T5 is really super value for money.
Nakedtoes
Huh? U sure boh? I thought now most Andriod phones can support aptx HD to up to LDAC? Samsung so lousy.. Lol
Nakedtoes
Dun need spend so much.. Just get the tronsmart spunky beat.. For the price of about $30 is the best liaoz.. It can easily beat those at $100 plus range.. With even more function like USB c and battery indicator.
Nakedtoes
Just recieved the spunky beat few days ago.. And pair with my JVC spiral dot tops with foam.. Omg.. Shiok.. The clarity is there sound slightly dark (wait for sound to open out more after burn in) . Bass is deep and thrumpy..gaphrene drivers is good sia.. I know it is use in mpow also.. And many $100plus TWS.funny is I dun know why I use neutron player the audio is cracking... Then use Winamp and power amp the amblum all list up haywire.. The in the end use hibymusic app.. That is the best liaoz.
Computeron
wa.... zun no? and the price is like $3x in shopee. :s13:
can beat mpow t5?
ps.. no more $3x liao... at least $40
Nakedtoes
Reviews say 1more ANC with the ANC turned on sounds very muffled.
Yeah that's the problem with anc..need to really get a good seal.. Then the anc works wonder... Same as Sony.. But Sony one is better.. Too bad their tws no LDAC else hoot liaoz. Only bad point for Sony is call quality.. I think they dun have cvc 8.0..i using the spunky beat for voice call..the other side is clear and loud.
Alexz_Hong
can beat mpow t5?
Aliexpres is an option, if not wait for lazada. I see it go for $34.90 every now and then. :s13: Personally I don't like the case design of the spunky beat because of the usb cable at the bottom and the built in strap. haha.
I'm still waiting for haylou gt1 plus and qcy t5 from lazada also. because of CNY and the virus, shipping taking forever. :s13:
Anyway, for Eileen007, https://www.scarbir.com/ has a ton of reviews of varying price point when it comes to TWS. If budget is $200, tons of options to choose from actually. :s13:
