DigDub
Is it worth the upgrade if I already owned the NT01AX? I'm still debating whether to get it or not.
If you want excellent sound quality, the N6 Pro is a superb choice. Else if you are not so picky about sound quality, then nt01ax is ok also.
ichinisan
Is it suitable for jogging? How is the latency like when watching videos?
DigDub
I don't think it's suitable for jogging, the fit is not super secure kind. Latency is ok, as most apps will adjust for it. Can try at Stereo.
rainbow99
Is it worth getting Anker soundcore at $96. Is it good at picking up calls clearly?
Sent from M20X using GAGT
kazuki666
Anyone want sabbat e12 ultra green marble? :p
Sent from Xiaomi POCOPHONE F1 using GAGT
ksksksks
Got the tranya b530. Fit like a glove. No fatigue after listening for hours. Plenty of bass but not as good as their T3. Vocals are clear. Volume is as loud as tevi.
The cons would be the use of micro USB cable just like the mpow t5 :spin:
kazuki666
I saw some bro pair it with Sony high end phones and it can work in TWS+ mode
Not sure about your phone. Mine was definitely not in tws plus mode. Its showing the connected one as master. As in this case the right earbud. And for switching, can just disconnect the right bud from this menu and tap the left bud to connect as master. For tws plus to work, phobe have to support. And using qualcomm soc. Unless samsung is able to provide tws plus function with a firmware update, which i highly doubt so.
I think the disconnect happens when the master earbud is being put back into the case?
It varies. Sony implemented some sort of true wireless plus, it connects both buds at the same time, so there's no master/slave connection for buds which support tws+. Most other manufacturers connect in master/slave mode even though the phone and buds support tws+, that's why you get a short disconnect and connect when you put the master bud into the case as the phone switches to connect to the slave bud from the master bud. Some tws buds doesn't do this, for example Sony wf-1000xm3, there's no disconnection when either one of the buds are placed into the case. And some other tws can only use one dedicated side for mono use. So it's quite a messy tws world out there.
It's normal. Most tws buds will ask you to pair the other side even though it's a master/slave connection. Some buds won't ask and only show one bud name in the phone bluetooth devices. The disconnect and connect is also normal for most tws buds, as you may have put the master bud into the case and the phone switches to the slave bud to become the master bud.
Maybe your DAP has a lower bluetooth version so it doesn't work.
I have no idea why. I tried to do the reset on my E12 ultra again today, it works liao!:s12::s22:
Ok, pairing on my mobile phone, its seamless. Unlike what happened to me yesterday. It could have been I didn't reset and pair properly no idea why though...
But still it has disconnection with my Sony NW-A30, which I am not surprised because it is bluetooth 4.2...
Btw, a DAP should work same as mobile phone seamless, if i get one with bluetooth 5.0 right?
I should be keeping these earphones for now.:s22::s13:
ichinisan
Thanks. Will probably give it a pass haha.
You should look at Powerbeats Pro
I feel that the Powerbeats Pro is big. Prefer earbuds which are smaller and fits well.
