Nakedtoes
Aliexpres is an option, if not wait for lazada. I see it go for $34.90 every now and then. :s13: Personally I don't like the case design of the spunky beat because of the usb cable at the bottom and the built in strap. haha.
I'm still waiting for haylou gt1 plus and qcy t5 from lazada also. because of CNY and the virus, shipping taking forever. :s13:
Anyway, for Eileen007, https://www.scarbir.com/ has a ton of reviews of varying price point when it comes to TWS. If budget is $200, tons of options to choose from actually. :s13:
I like the case cause the inbuilt cable is very useful when u dun have extra cable around. Qcc3020, USB c, inbuilt USB A cable, 4 battery led indicator, aptx support, ip5 rating, 7 hrs/24hrs case. For 30 can't find any value for money as this.. Closer is haylou gt plus at higher battery cap case but using USB micro.. Means no fast charge.
I fact I cancelled my haylou order and get spunk beat instead due to sound quality also.
Alexz_Hong
haha. yeah. depending on use cases lor. For me i know i won't be using the built-in cable at all for my type of usage, sometimes I not that careful with where i put my TWS, so it's a possibility that it might come in contact with water from like a cold drink on a table or what. Strap can probably DIY cut out too. But anyway, got quite a few folks tried that already, so less interesting to me.
Overall value, Spunky beat seems to be very worth it. Next up would probably be the MPOW T5/M5 liao. Good feature set and sound too. Used to be cheaper when I bought it last time, i think they up price after seeing so many good reviews. :s13:
I hooted gt1 plus cause still relatively new, and someone mentioned it sound pretty decent on headfi, so curious to try and see if it's better than the old gt1. QCY T5 also bought to try only since it got a good review for its sound too, but i already know i probably won't like it because of the stem design, even thought it's probably better for phone calls.
Alexz_Hong
Thats true. Theres a report samsung stopping exynos. Hope thats true. Just switch to qualcomm better.
The report only mentioned stopping their own custom CPU design. Most likely Exynos will continue to be around, but just using standard Cortex A series CPUs like what Huawei has been doing with their Kirin chipsets. :s13:
C32B
Which Anker model is recommended ?
Sent from OnePlus GM1910 using GAGT
justln
Their top of the line is Anker Soundcore Liberty 2 Pro, $120 now at Amazon with some code from AndroidPolice.
I'm using it currently, very good battery life and sound but have some white noise issue and no active noise cancelling.
lenseview
If thats the case, jia lat lo. At least enable aptx hd. Flagship phone without aptx hd is a joke lo. :s22:
C32B
Thanks for the recommendation.
lenseview
If not using Qualcomm SOC, want aptx need pay license fee, so I guess no one wants to pay for that.
Even those oneplus phone got aptx hd right? :s13:
Samsung charge premiuim price for flagship, include ldac but cant include aptx hd? Or samsung trying to force users to use their own samsung scalable codec? :s13:
chesterqw
Those OnePlus phones:
1) aren't cheap so idk why you compare it like that.
2) they using Qualcomm SOC, that's why got aptx for free.
Nakedtoes
THats why many tech savvy guys dun use samsung phones.. only non savvy one buy and haolian.. same as isheeps;)
Bardiel
will this sabbat E12 pro be a reliable one?
Looking around and it seems this price is the lowest i can find.
thx =)
