DigDub
But then won’t it be better to get the xm3 instead?
Depends. I don't use the anc or pass through function, so the h800 is better for me. Also I won't have to sacrifice one button for anc so I can assign it to volume button.
DigDub
Charging case size comparison.
DigDub
Price? How’s the fitting and sound quality versus wf1000xm3
Retail price is $299. Think shops should be cheaper a bit. The fit is like normal tws earbuds as the inner shell is designed like a conventional tws earbud. Very comfortable fit. Similar sound signature as the xm3, the h800 has a warmer mid bass but still retains the timbre and resolution of the xm3.
Tuakong
Just collected the E12 Ultra Red from carousell seller
Not bad but bass still not that strong despite tweaking the EQ
It's still a good buy though
Any TWS with good bass to recommend?
prataboy666
I got the Alpha & Delta Elite. It is a local brand. Pretty good strong bass and nice fit too. APTX support as well.
Had the E12 and didn't really like it. The fit is abit shallow for me.
You cann try at their adelphi outlet as well. I think i saw it in popular too but not sure if can try.
Jun Jun
Btw, those looking at noble falcon, the app is out. Just go to play store or app store and type noble sound suite. But some batches need to update firmware before able to use this app. The app is called noble upgrade.
patryn33
I hope ppl here looking for aptx support earphones not using any apple device
tohchr
Any particular reason why cannot use with Apple device?
Apple devices only support up to aac, it will be wasted (if I guess correctly what he mean). Generally, apple devices work best with airpods or airpods pro. In another hand, when using airpods pro with let say Huawei mate 20x, it will suffer much lower volume. This is my personal experiences.
Anything_Whatever
I c .... thank you for explaining.
Albedo
Been looking at Nuarl N6 Pro and NT110 recently since i sold off my Jabra 65T active. Using primarily for sports.
Does anyone know what is the difference between the two Nuarl models, since price wise one is double of the other.
Thanks.
arhjaye
Does anyone have comments for the creative outlier gold? Or like how does it compare to the cheaper TWS. tia!:s12:
Remless
Some flaws stated by buyers and reviewers below. Maybe u decide how they fare against cheaper tws.
1) Although they boast excellent earbud battery life, ironically many people cannot stand wearing it for long. Apparently comfort level is an issue.
2) It has connectivity issues which Creative had acknowledged and proposed a solution -https://www.scarbir.com/tws/creative-outlier-air-vs-gold-review
Jun Jun
Thanks.
Differences? Plenty.
N6 pro
3 buttons design basically made for single ear use.
Battery 8-11hrs depending on the codecs use.
With case 32/55hrs usage.
Sound quality-wise is more towards the vocals, bass is there but not too present.
Ipx4 water resistance
Nt110
Made for sports with ipx7 water resistance
Single ear button
Battery life 6.5-9.5hrs depending on the codec used. With charging case support up to 6 times.
Both can be used for sports, however if you are the careless type and tends to drop your earbuds into water then get the nt110. But if you care for sound quality more get the n6 series they can still withstand splash but definitely not dipping in water. Note: for thw N6 they have have a stronger bass than the pros but sacrifice in sound-stage/clarity and also for the pros they do come with a cp360 spinfit eartips which n6 doesn't.
