The Reporter
do u guys experience like softer volume on the right earpiece for e8 as compared to the left one? is it normal? and are u guys using the default eartips or u guys buy your own?
Gorgar
You must get the proper fitting. A slight adjustment makes a lot of difference. And you must try the various eartips size. There's cases where some people need to wear different size for each ear.
wizardmao
Using default eartips.
Try adjust to get the best fitting. For me sticking it all the way deep in isnt gd. Somehow muffed the volume.
doki81
Any one using E8 with lgv30?
Sent from LG-v30 Plus From Your Heart using GAGT
wizardmao
What codec does your E8 play in with your lg v30? Im using a pixel 2 xl.
doki81
No..I don't have it..but need to check if E8 user able to choose aptx hd for their E8 on v30...as 65t don't support aptx hd...
Think I got a lemon.... connected by Spotify still plays from phone... Spotify could not even see the earbud
Your phone need to see the bud first before Spotify can see it,right?
Gorgar
You're saying your buds are connected to your phone and when using spotify there's no sound from either buds or speaker phone?
Kegler
Yes.... very strange... fondle around with it... realised connected by B&o app is useless even thou iphone setting shows BT connected to e8....but i still need to get the e8 into pairing mode and pair again... now I see 2x e8 in my BT setting
Snoweagle
I find they're balanced. I'm using the silicone tip that comes attached to the earbuds. Those in the packet are still not touched.
wizardmao
Not sure for LGv30.
For my Pixel 2 XL, my E8 automatically connects to play using AAC codec.
Although from my device's settings I can see that available options for codecs are SBC, AAC, aptX, aptX HD, LDAC.
wizardmao
I find that size fits most ears, hence it's the 'default' tips. But for a better seal, comfort and isolation, comply tips are ones to choose. ;)
Idk if its my ears but I find it weird that the E8 if I were to push the eartip normally like I would with my other 3 type of wired IEM, the sound from the E8 would be muffed very softly. As if it is blocked. So always I need to gently slot it there without giving it much push.
Snoweagle
It's like that, the characteristic of soft silicone tips. So what I did was to just push it in until it rests on the ears, no need to push until so deep unless it's the dual or triple-flanged tips.
If you think it's still not 'isolated' enough, try the comply tips. The best fit is still my CIEM but I've already left the world of wired earphones.
doki81
if push too deep..until muffed..mean it's too vacuum ady..i get this when i use spinfit with my jabra elite sport..
