xilverr
need some recommendations for something that is under $100, main concern is comfort/fitting, isolation, battery can last 1 week for around 2-3 hours of use per day. mainly for music and video. device is pixel 3. thanks!
waikiki
Go for fiil t1x. No regret!
Remless
Thanks Remless for the reply. Am looking around for a good reliable ear piece and not willing to believe what websites say about their ear piece, therefore to seek the forum's bros n sis advice.
Thanks again.
The reason why I suggested googling for multipoint is not because to check out what the websites say, but to know which earpieces support this technology. Since there are not many, you can actually go and test it out yourself to see which earpieces actually performs to what they claim.
In this forums, most of us do not own a lot of earpieces to give an actual comparison. Some are just reiterating what the online reviews say. There are some who actually went on spot to test the call quality, like the bro below:
Both Galaxy Buds+ and 75T are suffering from the same issue (poor call quality). The 3rd mic on the Buds+ did help to increse the sound sensitivity however, it's still limited. Jabra on the other hand is still using the old tech (master slave tech instaed of TWS+) which is kind of dissapointing.
And there are some online reviews that actually say 65T's call quality is excellent (which u, as an actual user, feels otherwise) and 75T is an improvement to an already 'excellent' call quality. Probably that's why you do not wish to seek opinions only based on the websites.
The best is to find out which ones support multipoint, then go onsite yourself to test out the call quality.
PS: The bro eventually went on to purchase Anker soundcore liberty air 2, which he is enormously satisfied with the call quality. It does not support multipoint though.
007Mi6
Still the best budget pair for me atm
I bought this too at about $62 after some vouchers. 70% volume gives almost 6 hrs music. Charging box only gives 2 times more to the earbuds (eg 12hrs more, total full charge will give 18hrs of music)
Remless
I think a number of people would love to know how and where u get for $62. :)
I bought mine for $61.50 inclusive of direct shipping from taobao (arrive in 11 days) but that offer is over long ago.
The local sellers who brought in the earpiece kept increasing prices and now its $80+.
For the charging case, the manual states its able to give 3 more full charges (some reviews claim it can recharge 4 times fully). I am not able to verify since I don't use it for 6hrs straight and kept returning them to the case. Only thing I can say is I didn't recharge the case very often.
tc4237
Anyone has any - battery life extending tips - on using these wireless earpieces?
Is it okay to keep putting back into case to keep recharging? (like have memory effect and lower charging cycles?) or recommended to keep it outside until use batt nearly finish then put back into case to charge?
Gadgetfreakloh
Nowadays battery are more like expiry date. Not like pervious ni cd battery where got memory effect. Li-ion do not have memory effect. Use it as much as you like. Battery cycle is like 500 cycles then will be 80% capacity of original. Even not used will also degrade with age. Just enjoy your devices. Do not worry about all these. Also keep them always after taking out from your ears or risk misplacing them.
tc4237
Thanks.
Anyone got lobang for soundpeats truedots? Now that popular is closed...
ParkJinYoung
oooh. that's a pretty nice price actually.
Yeah, ends in 22hrs so plenty of time for those who wanna consider
The red version is $74.
But this is the Chinese version.
Anyway for me, warranty not tat important cos it's the same if I get stuff like these direct from taobao
I buy from Lazada, maybe can kpkb to Lazada if it's faulty
Sent from Google PIXEL 2 XL using GAGT
