kokfann
1. Call quality - I Guess it’s ok. Received no complaint during Zoom meeting (indoor and not noisy)
2. Single earpiece - yes. Did that during Zoom
3. Multipoint - Dont think so. So be No.
But I’m using T5S
Was considering to get a Bluetooth earpiece for calls (mobile phone) and zoom conf (laptop) then I came across this qyc t5, so now I wondering how is t5 call quality? Can I use just 1 side at a time? Example use the left ear bud for conf call till its battery flat then use right bud. Does t5 support multipoints?
Anyone know? Thanks.
kazuki666
Oooh. niase! So the 10 band EQ is user customisation? like i can change 500Hz, 1KHz individually? No need to stick with the default they provide? If so then it's truly worth it liao. even if sound profile not suitable can still tweak haha.
the location feature i find iffy, since the app itself needs location service (privacy concerns), and it's basically just recording the location when the earbuds were last connected to the phone. Which.. isn't that useful imo. If the customisation to the buttons and EQ is saved to the earbuds, then just tweak once, then uninstall already. haha.
My QCY T4... :s13:
I tried to go out of range to test the search function. Apparently turns it can't detect because not connection. Haha what a joke. Why I need to search if it's within connection range which is probably few metres...
Oh ya I had a WhatsApp with T4 just now. I can't hear clearly at times, not sure if the other side how is the call quality..
Sent from Xiaomi POCOPHONE F1 using GAGT
Sambuca78
But I’m using T5S
Thanks, will considering t5s or A1 earpiece now.
Currently using the cheapo xiaomi Bluetooth headset but it sound very soft although it has multipoint.
Alexz_Hong
It's one of the better ones already in this price range. Because of the stem, the mic is closer to mouth. Though if it's like a noisy place with lots of ppl talking around you, will still be not that great. Can use just 1 side. No multi-point though, and not that many TWS have that.
errr... then the search function kinda pointless already. hahaha. :s13:
kazuki666
Ask you all. I understand the usual bluetooth earphones cant connect directly to the laptop / desktop directly. Is it need to get additional gadget to connect?
Alexz_Hong
If your computer support BT, should be able to. I've used TWS with my desktop at home.
messi7
Hi guys, very new to true wireless earbuds
May I know what are the good options for budget of $100? I prefer one that has a good bass
Many thanks in advance
Alexz_Hong
You might want to check out https://www.scarbir.com/ since he has reviewed a ton of TWS, and I've found his reviews to be pretty accurate.
If you want a more audiophile's perspective with frequency response graphs to back them up, https://crinacle.com/guide/tws/
:s12:
kazuki666
Then I suspect could be my laptop top old le. It does have Bluetooth because am using Bluetooth mouse. It's 5yo so I suspect Bluetooth driver and version could be damn outdated... Get a USB Bluetooth adapter should should the problem right?
Alexz_Hong
but like weird leh, earlier this year I got try using TWS like Mifo O2 with my 2013 iMac, still can use. Not sure if it's OS difference or what. The laptop doesn't detect the TWS at all even when it's in pairing mode?
