Remless
Firstly, Thank you all for your replies. I guess I'm doing it wrongly.It's based on my 15yrs of handphone useage.My wife likes to charge her hp even at 50%.After a yr,batt can't even last 1 day.For me,I will always wait till 15% then charge.After 2yrs,I can still get 2 days usage per charge for my hp.So like what all of you recommended, just put the buds back into the case after each use.Today I put it into the case 3hrs before my run.Got 100% for both buds.After 1hr run,still had 82% each side so will put into the case tonight. Thanks again for all your help. Appreciate it.:)
No worries man.
But lol, I am worst than your wife. I charge my hp even when its at 70%. Hp battery these days which can last more than 1 day is rare now. Mine usually don't last one day, probably heavy usage (gaming, streaming, etc).
Remless
Speaking of which...
Lol... as always. New models always pop out without warning. Sometimes even my bunch of tws is still working well, the 'gian' to buy is there when there is things like these for sub-$100 and the price is dirt cheap.
Looks like they streamlined the biggest complaint of t1x..... the case.
Gadgetfreakloh
Lol. That's why currently I have only sub-$100 tws and pretty much consider them as consumables. So far, I guess I am quite 'heng' as the ones I bought from taobao/lazada china sellers/shopee china sellers/aliexpress have no issues at all.
IMO, there is no best tws, only a tws that meets our needs and at the price we are willing to pay. For something as trivial as tws, there is only this much I am willing to pay now and I just buy, consume, replace with new one when they wear out.
Yes. Agreed with Remless bro. Current gen of tws are both good and inexpensive. My tws journey from 2016 are super expensive and very unreliable connection and super bad battery life. Not to mention the sound quality are not as good.
Just 4 years down and there is tws costing $20plus with aptx! Unbelievable but true. So is there still value in tws costing $400 plus? Probably their days are numbered.
My current most used tws is MTW2. I loved it. But if the MTW3 still launch with $400 plus price tag. Then I will consider very well if it is still worth the price versus the onset of cheaper models on the market.
Remless
Currently sound quality and the ANC hype is there (Thx to Apple and their Airpods pro), so they can ride on the wave and charge high prices. Maybe future MTW3 will have another technological breakthrough, like unbreakable connection that lets u listen to music when your phone is 10 floors up. :s13:
Then they will charge premium prices again.
Currently there is another neat feature that are already implemented in some tws. Forget abt button controls and touch controls. We can now control the earbuds solely using voices to answer calls, control volume, skip/return tracks and even search songs, etc. Qualcomm will have this feature in their new premium chips.
chesterqw
Battery health and life depends on many factors; discharging your battery till it is almost empty then charging it will cause more wear compared to discharging to around half then charging.
Fast charging causes more wear as well, as it also increases the temperature the battery is experiencing.
How much you use your phone is also another deciding factor, a phone that is constantly being used would obviously have their battery drained compared to one that is not. The applications you have installed, if they are constantly checking for updates or push notifications would also use up more battery, which almost all social media applications do.
Gadgetfreakloh
I do not fancy voice control. Imagine doing that when in the public transport or even office environment. What I fancy are aptx-HD with 3 drivers with ANC with at least 7 hours earbuds battery life. If you heard about this features in a tws please sound me out.:D
Remless
I am sorry to say that it seems that qualcomm is excluding APTX HD, APTX LL codecs in their latest chips, even the most premium ones. It seems that they want to streamline their codecs to just APTX adaptive and APTX standard.
APTX adaptive cannot output APTX HD's level of bitrate (but still higher than standard aptx)... but its able to switch bitrates depending on strength of bluetooth signal. Its like auto low latency mode in crowded areas.
This seems to be the direction qualcomm is going.
Good thing is ANC will be there as a standard feature, as well as TWM, a better, more seamless earbuds switching technology than tws+.
chesterqw
There is the Aviot TE-BD21F with triple drivers with 8 hours max playtime, no aptx hd, only aptx though.
Gadgetfreakloh
This I am using. The sound is not very forward. Not much energy in the sound.. but is balanced.
Also its diaphragm will creak when push into ear canal. Definitely is air tight but very annoying.
chesterqw
The diaphragm crinkle you described reminds me of the creative ep630
Gadgetfreakloh
Thank you for the information. APTX adaptive should be good. Let see what features they can put in.
If any manufacturers hear me. 3 drivers, ANC, pass through, Aptx, 8 hours earbuds life at less than $300?
Gadgetfreakloh
Lol. This BD21 is very comfortable but is like a Frankenstein with the 2 long end sticking out. The tuning is very Japanese which I do not really fancy.
Not much people using this too and very difficult to sell. I do not advise anyone to get this.
Gadgetfreakloh
Never a fan of fast charging. Always do normal charging. I also stay far far from wireless charging. The coil is normally above the battery and will heat up the battery. Previous phones that I use wireless charging the battery will always bloat.
kogregory
I must admit the BT5.0 for the T1X is superb.No drops.Previously on Plantronics PLT 350.BT4 i think.When running pass the same buildings,signal will drop.I also tried playing the T1X loud.No distortion so far.Truly great sound for the price.
chesterqw
Thank you for your sacrifice in hooting it
chesterqw
Is the T1XS available already?
it's out inside China, probably takes awhile before they start selling it globally.
you can find listing in taobao mobile if you aren't logged in and not using the singapore listing.
