justln
Oh! Thanks for sharing. Any other models that you recommend which does not have the white static noise?
Liberty 2 Pro have the static noise, I think all the newer earbuds have this issue. Google Anker white noise, quite an irritating issue. You might not notice this if you're in a crowded area and music/sound is constantly playing but in a quiet area, damn annoying.
Too bad though cause their music quality and comfort is really good.
xxSaDanxx
Just google for this issue after been shared by you. Seems like the noise is quite irritating..looks like I have to shortlist other model.
Does this only applies to Anker model? So other brand will not suffer the same noise?
Eileen007
I bought a pair of Truedots from Popular. The right side earbud can't charge anymore even though I used it less than 10 times
happily1986
see if you can do a warranty return i.e. RMA. If really thats not an option, you can try to examine the charging pads on the earbuds and the pogo pins in the charging case.
For my case, i believe the charging pads on the earbuds get slightly oxidised over time due to use. So what i do is to gently brush it or even scuff it, that usually does the trick.
kazuki666
In case if anyone keen to know the differences
T5S vs T5 Pro
T9S vs T4
@alex. Apparently T4 volume issue is a bug for all the sets... :(
Alexz_Hong
T5S vs T5 Pro
T9S vs T4
haha. yeah. saw the video the other day. So i guess T9S is the way to go. T5 pro's review doesn't seem too favourable too. haha.
kazuki666
I guess newer releases always get the improvements bah.
T1 > T4 > T9S
T5 Pro loses to T5S mainly due to the sound quality, even though it has the advantage of wireless charging. Apparently the motion sensor may not be that sensitive. See if anyone here hoot le can share more details bah. :D
Lesson from T4, i think i will wait see if there is a later version for the stem... :s22:
Rated R Edge
Is Jabra Elite Active 75T good for running? Saw that if apply Stand Chart credit card got promo can get free.
The only true wireless earphone I ever used was Sabbat E12 Ultra for running and it sucked big time cos keep slipping out of ear when sweaty and think abit spoil cos got explosion sound once in a while. :s13:
xxSaDanxx
Maybe u can consider Anker Soundcore series? I am using Liberty Air 2. Decent audio quality with excellent voice call quality. With 12 months LOCAL warranty as well.
Thank you for your recommendation. I got a pair and received them yesterday.
Tested and found that it wears better than Fiil T1x.
Maybe my ears not so sensitive, did I not notice the infamous white noise.
justln
Spoilers if you don't want to notice white noise, don't open.
Go to a quiet place like your store room or toilet, start playing some music then stopping. If there is white noise, you'll notice static playing 2-3 seconds before and after any sound.
luckygal
For $100 plus minus, possible to get ear buds with decent music quality (a bit of bass would be good) plus good noise cancellation coz at times have to talk outdoors. Thank you for all the seniors recommendation.
If I more or less decide on Soundpeats, is trueshift 2 a good buy that fits the above criteria?
gkhchay
Can anyone recommend one that has multipoint capabilities ie being able to connect with multiple devices simultaneously eg phone, laptop & TV. And also no/minimum audio lag when on video conferences & watching videos. Thanks.
JamesTBD
I just got mine. sometime cannot connect. Music quality so so only but for the price... its expected.
Computeron
i have used elite 75t for running. wont drop
seanyboydad
Think have to pay the annual fees of 190++. Net still cheaper than outside price of about 300.
Sent from OnePlus IN2010 using GAGT
