kazuki666
To those first timer. Honestly I will suggest you try the stuff like Xiaomi QCY, $30 range. Who knows, this is good enough for you.
Sent from Xiaomi POCOPHONE F1 using GAGT
luckygal
I saw the SoundPEATS n QCY official store at shopee. But can’t find the Haylou official store at shopee. Is there one at shopee?
kogregory
For those that use your earbuds for jogging, I just got a Shanling M0 and use it with my Fiil T1X. Amazing power and sound definition from such a small DAP. Fantastic combination IMO for those super long runs. So much clearer than my cheap China player I got from Aliexpress.:s12:
bran36
Anyone using Lypertek Tevi? Facing reduced sound on the left earbuds. 6 months usage only, didn't drop. Mostly used for runs, maybe sweat too much? Luckily still got warranty, but tempted to get a new pair. The Fiil T1X sounds good! Anyone have both? :s12:
gong318
using lypertek, I noticed the left side do have reduced volume at times too. But this can be solved by increasing/decreasing volume for me.
I've tried both fiil t1x and lypertek tevi, fiil has a more dynamic sound with more bass while not compromising on highs and vocals while lypertek delivers on the vocals. Had to return my fiil due to QC issues.
Sent from OnePlus GM1910 using GAGT
kogregory
The sound quality from the T1X is quite amazing but I'm still having issues with the touch controls. Can't off manually.Have to put into the case after each run. The case can only charge 3 times even though when the case is low on battery, it should start flashing red. On one occasion when I took the buds out, the left side was flat. There was no warning to say the case battery was low.My next buds will probably be an Anker with button controls. Even my wifes cheapo TWS F9 V5 $20 can on & off the buds with the button controls but of course sound quality is just ok only. I highly suspect my T1X is a quality issue so my next will be one with 12mths local warranty. I tried the Lypertek at Jaben. Quite impressed but I still think the T1X sound quality is much better. Most likely will wait for availability of Anker Soundcore Spirit Dot 2 locally then will order to try.
davidwong
Yo bro there is off ie when you off press on the bug and the light become red that is off and when you put the bug into the case the light (on the bug not the case light) will also turn red indicating off.
What you want is auto stop charging when full in the case is it? If that’s the case I have mixed review, there is times when I used and the bugs Low batt I put in it will charge to full and the buds light will off (I charged opening the case lip)
Then there are also times I put the buds into a fully charged case and didn’t use for more than a week, when I connect the bugs the bugs themselves are fully charged but my case is flat
Lastly got times as above fully charged case put in buds and didn’t use it for a week and when paired the buds are 56% charged but the case is flat
bran36
Hey, thanks for the feedback. For my Tevi, I tried turning on and off, putting back to the case and resetting the earbuds but the original volume didn’t return. Right side is still louder. Sometimes the problematic earbud gets really soft.
Hey, thanks for the feedback. Seems like this Fiil have some QC issues. Dependant on one’s luck, I guess. I think I will do a warranty on my Tevi and see how it goes first.
kogregory
Not everytime when I touch to off the buds will the red light come on.On the left side, I can touch do this for 3mins but the red light still doesn't come on. Like what I said,my wife's cheapo $20 ones can turn on & off every single time with no issues coz it's a non touch design. U have to press the button. If the case batt for the T1X is low, it should start flashing red right? Never saw the flashing light so I have decided to charge the case after 3 charges. Don't get me wrong. I really love the amazing sound quality of the T1X but to me there seems to be quality issues. Also wondering why a simple no brand $20 TWS can seem to have no issues when my T1X has quite a few.
kogregory
Or I am doing it wrongly. When the R red light comes on when I switch off, does it also mean the L is off even though the L doesn't have the red light come on?
davidwong
Yes no doubt Fiil T1x got QC issue like my 1st pair of T1x so 2nd pair bought from local seller with 6 months warranty.
