davidwong
Any good below sgd120 ANC TWS with good connection?
Actually how to you grade anc now becos there is no std edifer onemore sony AirPod pro all anc but all different level now do we choose. I will like trying anc but should I go in now or wait?
I am looking at anc that can cut off 80% of mrt shrieking track noise in the mrt, at home to able to filter out drilling noise from neighbours or reduced (not possible to filter) kids screaming and shouting when playing along the corridor , all without breaking the bank (very small piggy bank only)
justln
https://www.amazon.sg/Soundcore-Cancelling-Headphones-Wireless-Bluetooth/dp/B07NM3RSRQ
Anker ANC but headphone, earphone very hard to get that price without it being super crappy.
Alexz_Hong
https://www.scarbir.com/guide/best-cheap-tws-with-anc
scarbir has a list that you can look at?
meowth82
yup sorry thats what i meant. what are the models below $100? used to own mpow t5 and soundpeats
Soundpeats Truengine 3 SE is using type c. Fiil T1 x and T1 XS both also using type c. Those 3 TWS that I know are using type c and below $100.
DarthGW
i was looking at Soundpeats taobao store..there is Truenegine 3SE, Trueengine 2, TrueShift2
i am not sure what is the main difference in features? all look about the same
ichinisan
hooted fiil t1xs..the downsize case very portable, fit into jeans well.
It really looks very portable. How is the bass for this?
meowth82
3SE is the latest release. Different should be very minimum for all 3.
vofzxy
https://www.xiaomitoday.com/fiil-t1-xs-tws-earphones/
FIIL T1 XS TWS Earphones Avialble at $79.99
Photo of Piyush Sharma Piyush Sharma Send an emailMay 22, 20200 2 minutes read
FIIL officially launched the third true wireless sports headset-FIIL T1 XS. As the name suggests, “XS” is smaller, more portable, and smarter. Compared with FIIL T1X, T1 XS has a lighter body type, multi-scenario low delay, ENC dual wheat noise reduction, wearing sensor, automatic intelligent start and stop, listening mode, more powerful functions, and more color matching features.
FIIL T1 XS
Buy The T1 XS TWS Earphones on geekbuying for $79.99
XiaomiToday Best Deals
Specification
General Brand: FIIL
Color: T1XS
Color: Black
Specification Bluetooth Version: V5.0
Transmission Distance: 10m
Decoding Format: AAC, SBC
Playback Time: 6H, 24H with Charging Case. Charge 5 mintutes and you can listen to music for 1 hour.
Charging Time: 1.5H for charging case, 40min for Earbuds
Speaker size: 6.1mm
Frequency response: 15Hz~22kHz
Sensitivity: 95dB SPL@1mW
Distortion: <3%@1mW
Dimensions&Weight Product Weight: 4.8g/earbud
Charging Case Weight: 29g
FIIL T1 XS :Lightweight and compact, comfortable to wear, let your freedom without worries
FIIL T1 XS has a smaller storage box and more colors. Compared with T1X, FIIL T1 XS has a weight reduction of about 30%, and the weight of the charging box has been reduced from 42g to 29g. The storage method of the earphones is adjust from the vertical arrangement to the horizontal direction. This maximizes the internal space of the charging compartment and has good anti-fall and impact resistance. In addition, FIIL has upgraded its unique open-box flash connection function, flash connection 2.0 technology, with faster connection speed and lower power consumption.
FIIL T1 XS
FIIL T1 XS uses a low-latency dual-channel transmission system, and the left and right ears are connected to the mobile phone synchronously, which fundamentally reduces the delay. And for the three scenarios of playing games, listening to music, and watching videos, the transmission scheme is tailored and switched as needed. With capacitive touch, both ears can be operated independently. Two control schemes are preset in the headset, and the operations of play, pause, and answer are completed blindly. FIIL T1 XS adds a wearing sensor, which will automatically detect the wearing status.
High-definition call, long-lasting battery life, long enough to be “heartbroken”
FIIL T1 XS
FIIL T1 XS uses dual-microphone call noise reduction technology to attenuate the environment by 90% of the noise in real time and achieve better noise reduction. It also joins the listening mode, through a dedicated microphone and intelligent algorithm to filter vocals and moderate ambient sound into the headset, you can capture a wider range of noise from traffic noise to vocals, daily noise and more.
FIIL T1 XS
In terms of sound quality, FIIL T1 XS adopts a high-definition decoder chip that meets Hi-Res requirements and a 6.1mm high-density rubidium magnet custom dynamic coil unit. Wang Feng checks the sound quality and configures the audio system according to the standard of professional music headphones The performance is worthy of recognition.
cochran
any improvement in sound or sound better for the FIIL T1 XS to the older FIIL T1 X
meowth82
Just received. Overall satisfy with the sound quality with this price. Not sure how it compares to T1x as I didn't try or own before.
Sent from OnePlus IN2010 using GAGT
ccloh
the soundpeats official store in Aliexpress last week was having promotion on the 3SE. after getting vouchers and discount, you can get it for under S$60. here SG next month then they bring in the 3SE, this was told by the official store in shopee.
DarthGW
will be getting from soundpeats taobao..slightly cheaper.
evilster
shagged.... i bought a new qcy t5s and it just die on arrival... can't even charge the earbuds.... I can't even get a refund...
justln
Any noise cancellation ear bud to intro?
From most expensive to cheapest
Sennheiser Momentum True Wireless 2
Airpods Pro
Sony WF-1000XM3
1MORE Dual Driver Noise-Canceling True Wireless In-Ear Headphones
Sony WF-SP800N
Mpow X3 in-Ear Bluetooth Earphone
Wired:
1MORE E1004
