DigDub
From most expensive to cheapest
Sennheiser Momentum True Wireless 2
Airpods Pro
Sony WF-1000XM3
1MORE Dual Driver Noise-Canceling True Wireless In-Ear Headphones
Sony WF-SP800N
Mpow X3 in-Ear Bluetooth Earphone
Wired:
1MORE E1004
Got a new one audio technica anc300tw.
DigDub
Audio Technica anc300tw. Balanced sound signature, needs to use with ANC on for higher volume and sound quality. Very comfortable to wear.
davidwong
According to the reviewer, the ANC is about 50% NC vs Sony which is about 90% NC
But x3 is 1/2 the price of Sony
Any bro think I should go have a try or wait? By the way I am using it with my IP 11 pro maybe thing to give some peace and quiet for WFH
https://www.androidcentral.com/mpow-x3-review?amp
fireduke86
Can I ask if you tried using it to watch movies and Youtube? If you did, any perceptible lag?
musicsg_com
Airpods Pro
Sony WF-1000XM3
Sony WF-SP800N
Wired:
1MORE E1004
For budget conscious, I recommend Huawei Freebuds 3i. ANC quality is exceptional, supports ambient sound.
Audio quality is not bad, strong treble.
Sony SP800N is basically a sports version of 1000XM3 with longer battery life and better IP-rating. ANC is not as powerful. You can store your EQ in the earbuds so you can adjust to your favourite EQ.
Sound quality is slightly dark, but it also means more comfortable to listen to for hours. With flat EQ, the bass is not that massive, but if you prefer bassy, just adjust EQ and you will get your craving satisfied.
DigDub
Soundpeats truegine 3 se.
In its case.
Close up of the dual drivers.
Very good mids. Vocals come across as clear and not muffled. Highs sound crisp and we'll defined, not sibilant. Bassy overall sound, the bass could use more definition. Soundstage is pretty much in the head and intimate rather than spacious sounding.
Compared to the truegine se, this one has a lower profile and doesn't stick out from the ears as much. The sound on the 3se is also clearer, the SE sounded muffled with woolly mids and highs.
Nakedtoes
In its case.
How much?.....
