DigDub
!!! soundpeats flagship on tmall selling for $60 sgd
I usually buy from brick n mortar store if it's available locally and the price difference is not too much. Easier to exchange if something wrong.
DigDub
Soundpeats true free 2. It's based on the QCY T1C which was one of the early affordable tws earbuds available. It retains the fun big bass sound of the T1C which makes listening to it very enjoyable. Treble and mids are clear and coherent. It also retains the 4hr playback time of the T1C.
The things that has changed are the buttons. The T1C had a easy to click plastic button, the true free 2 has its button under a rubber cover which makes pressing harder, presumably to make it ipx7, up from the ipx4 of the T1C. The true free 2 also has 2 major usability improvements from the T1C, it now has volume control and is able to use either side of the earbuds independently. Soundpeats has also added wing options for a more secure fit.
hotspur_77
MPOW X3 ANC works fine for me. Sounds good enough for me and able to control volume up/down by single tap.
Read this from Mpow, is it true?
Question: how can I connect left earbud only ?
Answer: Dear Customer, thanks for your question. Only right earbud supports mono mode (Press and hold the MFB of R-earbud for 2 seconds). If you want to use th left earbuds only, you can connect two earbuds to your phone device firstly and only use the left earbud, and put down the right earbud. Please kindly noted that The mono(right) mode does not support ANC.
Qoojay
Found a local seller in Lazada for a pair of Powerbeats pro at a much cheaper price than the RRP. Is Lazada trust worthy?
meowth82
hows the verdict for these two?
Soundpeats 3 SE:
Love the sound and I guess is due to the dual driver
Earbuds slightly bigger size but easier to wear and handle
Case is larger compare to FIIL - minus point
Low quality of packaging and build - minus point
No App - minus point
FIIL T1 XS:
More premium build compare to Soundpeats
Smaller case
Good sound quality with this pricing
Smaller earbuds and a bit harder to handle
Got it own app (china region version app)
zhihe1996
Soundpeats 3 SE:
FIIL T1 XS:
Smaller case
Ps if no app isit possible to tell battery of earbuds in android ? I using mate 20 pro. sorry for noob ques. asking for soundpeats 3se.
justln
Your phone should be able to show the battery life of your bluetooth earbuds even without app.
meowth82
Yes, Bluetooth page will shows the individual earbuds battery as well even though Mate 20 Pro have limited space of icon display on top of the phone.
DigDub
Some phones like xiaomi got an icon at the status bar area to show the battery level. Most phones can see the battery life from the bluetooth settings paired device page.
gong318
Soundpeats 3 SE:
FIIL T1 XS:
Smaller case
which has better sound?
storm913
I have and currently using these:
1. EOZ Air
Very comfy
Bluetooth connection is strong
Cannot use mono
Can use comply tips
Old tech already, not recommended
2. Soundpeats Trueshift 2
Great bass
A bit big, but fits nicely and comfortable
Used for running since good IP rating
Mic is decent too
Huge case but crazy battery life
Good for gym bags or bigger bags in general, not pocket friendly
Taotronics 79
Great sounding
Small case, very pocketable
My daily driver for now
Good fitting on ears too
Looking to try Soundpeats 3 SE soon and maybe Fiil T1 and lyperteck too.
vofzxy
Great bass
Mic is decent too
Taotronics 79
Great sounding
you bought from lazada /shopee?
sirnefleur13
I'm using ZNT SoundBass IPX7. Overall sound quality is really good and the price is very reasonable too. What I like about it the most is how fast it charges. Everytime after you use, just put back into the casing and you only need to charge casing maybe after one whole week! I got my pair from Shopee Mall so it is authentic and also comes with a warranty! Highly recommend you to get from the Mall section when there are sales :)
