zhihe1996
Just got the 3SE. The manual says dont use quick charge adaptor to charge the case. Those who have it use pc to charge ?
justln
got such restrictions one... Omg
I know some electronics cannot quick charge or else will spoil the device, maybe cause lower quality they never put resistor/controller in. PS4 controller if use quick charge = GG. :s13:
Nakedtoes
oh must note liaoz i always charge my small tws device through quickcharge
iteo74
Hi all. Need some help. Shortlisted the below models and want to know which better for calls? Mostly indoors but calls are for work so cannot compromise too much on quality too, but need to control budget too. Thank you !!
1. Soundpeats Truedot
2. Lypertek Tevi
3. Anker Liberty Air 2
bedlamite
It's for work, don't play play. Get a 15-dollar Logitech headset, great mic and no need to worry about battery life. The 3 TWS you've mentioned aren't known for their mic quality.
iteo74
Thanks but not considering headphones as it will be too hot after long hour and doesn't exactly look professional :p
justln
2. Lypertek Tevi
No to any Anker 2nd generation earbuds, just google Liberty 2 white noise.
And yeah, why even bother with wireless earbuds if work call quality is the priority? Even expensive wireless earbud call quality aren't fantastic.
iteo74
Because cant be using phone and headphones are not professional looking. They both get hot in long meetings.
Doing a lot of zoom video calls with mid-senior level people.
justln
Wired earphone is a thing? Mic quality will probably be miles better than any wireless earphone.
iteo74
Lol. Is it that bad to use Bluetooth? I've tried wired and feedback alot of background noise. Is also restricted at times because I can't move around if I use it with laptop.. is also about convenience lol
bedlamite
Lol nobody is going to look down on you for wearing wired headphones.
My wife has been WFH for months and been in endless meetings with mgmt. She rocks atrocious looking Logitechs...nobody cares.
If keeping up appearances is so important to you splash out for Bose QC35s. It's got a good mic, battery life won't last like half a workday, and it's comfortable. Stop dicking around with Chinese TWS.
Anything_Whatever
Aftershokz Aeropex is the best headset for WFH meetings.
https://aftershokz-com.myshopify.com/products/aeropex
Good mic and good hearing sound ... it is a bone conductor headset btw...
You can demo at Westgate B1 Stereo or at Popular bookstore at IMM and IMM Challenger.
ksksksks
Sad but true.. the only earbuds known for better mic quality may only be AirPods Pro and Jabra 65/75t.
Albedo
Not sure about Jabra 75t, but the 65t was atrocious with phonecalls and that's why i sold them.
