Nakedtoes
Oooo... party on other side can hear when background is noisy? For both models...
Those model that got cvc 8.0 can remove background noise. Some did it better... Anc is mainly to remove environment noise when u listening to music. However u must know that Anc might also affect the music quality also as it treat the sound output from the earphone as noise and remove them. So far I see Sony Anc is the best in the market.. U need to wear it with good seal.
kazuki666
I think some members here may know the youtuber Kenneth. He just did one video about various models on call quality. One thing interesting about his channel is that he usually test those lower price range models.
Nakedtoes
Soundpeats 3 SE:
Love the sound and I guess is due to the dual driver
Earbuds slightly bigger size but easier to wear and handle
Case is larger compare to FIIL - minus point
Low quality of packaging and build - minus point
No App - minus point
FIIL T1 XS:
More premium build compare to Soundpeats
Smaller case
Good sound quality with this pricing
Smaller earbuds and a bit harder to handle
Got it own app (china region version app)
Which one better in SQ?
davidwong
Anyone heard or tried Ticpods ANC now selling at Lazada at 120 only I saw a few reviews seem not bad but the sound is abit bassy
sKeLeToN
Hey guys, i'm looking to get a TWS earbuds for work...so looking for one that has good connection, voice quality and decent battery life coz go on skype/ zoom calls quite often...
Any recommendations below S$100? I've been reading this thread and leaning towards the soundpeats truengine 3 se, but not sure if there are more appropriate ones out there...
My laptop is still running the older BT4.2 version...not sure if it will impact the benefits from some of the latest tech that enhances call and voice quality...
storm913
Just received my soundpeats 3 SE. Extremely satisfied with the audio quality! Especially with comply tips. Will be my daily driver from now.
Gadgetfreakloh
Which one has best anc?
Personally used Sony Wf and currently using MTW2. Did not like WF as the passive noise cancelling not good. The active is not bad.
MTW2 passive is very good. Plus the active NC. They are very effective. One more good point is with the NC on. There is virtually no degradation of the sound quality.
justln
MTW2 very meh for the price according to this youtuber.
Gadgetfreakloh
Got a few good and some no so good. Majority give it very good review. I suspect the reviewer has a Ear shape that is not fitting or suitable. You need to have very good fit for these to work well. Once you can confirm that the fitting are done right. The output is heavenly.
These are not for everybody. Important to test them first.
