Vulpix
Moderator
Moderator
Anyone got any opinions to share on the Sennheiser MTW 2? Is it a huge improvement over 1? No more battery issues?
meowth82
Check out this thread.
https://forums.hardwarezone.com.sg/headphones-earphones-portable-media-devices-314/impression-sennheiser-momentum-true-wireless-2-a-6298177.html#post128175416
ThinkMe
Okay to buy the FIIL T1XS from gearbest? See the price is like 70 bucks.
Nakedtoes
Just received the Edifier X3... SQ is not bad, pronounced forward treble which i like .. so far SQ is better then Tronsmart spunky beat. However volume is quite low.. i need to max up the volume listen... (tried disable and enable absolute volume in developer mode ... no use ) Mid is lacking, bass is trumping that is
if u get a good seal (i using JVC spiral dot tips with foam)... see burning in few days got improvement or not... :(
jyyj87
Received the English version (English voice notification when connecting to BT) of the FIIIL T1X a couple of days ago. The sound quality is really good (coming from AirPods and AirPods Pro).
I didn’t even need to use the EQ. The default sound is excellent already.
Pairing with iphone was a Breeze. Both sides connected to my phone within 1-2 seconds at the same time.
Took it out for a run too. No issues.
If anyone is looking for a very good wireless earbuds for < $80, I highly recommend the FIIL T1X.
My set was shipped from China but the delivery took only 1 week.
https://shopee.sg/product/212023130/4016939647?smtt=0.0.9
ralliart12
Received the English version (English voice notification when connecting to BT) of the FIIIL T1X a couple of days ago. The sound quality is really good (coming from AirPods and AirPods Pro)...
Is the Airpods Pro SQ really that cui? Or is the T1X too good?:s13:
kokfann
After my QCY T5S gone case due to problem when upgrading firmware, I switched back to my Airpods
Yesterday received Mpow X3 and is satisfied with it. It is comfortable even wearing for long period, similar as Airpods. ANC works fine, good actually. Very effective in blocking noise in MRT. At $60, this is absolutely a no brainer to get.
jyyj87
the Airpods Pro sound quality isn't bad btw. I think Apple went with the kind of sound signature to try to please everyone.
It still sounds decent with good mids and treble. I just find the bass surprisingly lacking despite the in-ear design. Using the EQ does help. It adds value with the ANC (works really well when im taking the mrt) and the transparency mode.
The FIIL T1X on the other hand, even though it lacks ANC, it's tight fit is already effective enough to block out majority of the surrounding noise. I went running with it and all i could hear was my breathing and the impact of my steps. Oh and the FIIL T1X already sounded very good without having to tweak the EQ.
DigDub
Connect-IT now carries Panasonic headphones and iem. Got the new rz300 and rz500 tws.
standing
Looking for affordable wireless earphone.. I saw this saisho noah true wireless earphone at challenger.. $59.
Anyone use before?
Halo green
what type of earphone should I get if used for zoom on iPad/laptop and sometimes can listen to mp3
vofzxy
{Local Ready Stock} Sony WH1000XM3 / wh1000xm3 / WH-1000XM3 Bluetooth Over-Ear Noise Cancelling Wireless Headphones / Earphone 12 month warranty headset with microphone
$296.99
$529.00 -44%
https://www.lazada.sg/products/loca...t-with-microphone-i485272301-s3753534172.html
good deal mah?
i suppose you want wireless ones right? stem design ?
got QCY, tronsmart, nuarl, Fiil 1tx, soundpeats, haylou GT1, xiaomi airdots....
which ever you see on NDP sale this weekend, suits your budget, go ahead lor
