animeonegai
ordered soundpeats truengine 3 se liao. $64 after store lazada discount coupon
gong318
Hi. Is it the trueengine 3se? How is call quality? Thank you!
hi can't comment on this as I don't call often. however from sound samples I heard from YouTube I would say that it's actually not that good.
tohchr
Received Challenger email says it's exclusive to them? Interested in the buds live due to its innovative form factor.
If u interested in Bud Live, I suggest u wait for Note 20 ultra users to get their phones, many will sell their Bud live at a much cheaper rate in Carousell.
iteo74
received my soundpeats. touch controls works unexpectedly well.
comparison with my lypertek tevi that I had:
lypertek is more detailed has more clarity. the mids and highs are better but never too bright for me. the bass on this set is tight and just enough to complement the music, but on genres which has more bass (hip hop) you might not be fully satisfied because of the lack of thump in the bass. my Chinese songs that I listen to are superb on this set, presenting a clear and articulate sound. female vocals shines especially on this set, beingway more forward here.
the bass on soundpeats are more well rounded and has more thump,but never overpowering the vocals. I personally feel that soundstage is wider on this set. this set is overall warmer and well rounded. despite all this, this set still presents a detailed and balanced sound. pop and hip hop shines in this set.
depending on what songs u listen to, I'm sure both set will satisfy you. personally don't feel one set is better than the other.
DigDub
Detailed sound with ample bass. Superb noise cancelling and ambient mode, I think better than Sony. Good battery life, compact case. Got app can adjust ANC and ambient mode levels and 5 band equalizer. $279.
galliano
Just to share:
Received my $9.90 TWS F9 BT5.0 ear buds earlier today via EZBUY.
Well, It worked fine.
Comparing it with the cheapest ear buds I own - Xiaomi Airdots:
Pros:
Sound quality: has bass. Pretty decent. Must better than the Airdots for sure which was solely lacking in any form of bass. For music .... Titanum (David Guetta) sounded ok. Lacked detail .. but its still ok.
Connectivity: Bluetooth works. Pairing & re-pairing worked fine
Price: Its $9.90. Cannot complain
Gaming latency: very slight. Not exactly noticeable. Using a cheap BT USB dongle with my PS4. And it connects automatically every time w/o any issues. Bass as sufficient especially during COD Warfare
Fit: Decent. No complains. Came with 3 different tips.
"Touch" controls: worked fine
Cons:
Buzzing sound: Its got this slight buzzing sound. Its definitely noticeable in some of the cut-scenes in Ghosts of Tsushima. But I did not get it when paired with my iPhone. Suspect the problem is my BT USB dongle on my PS4.
Casing: huge. But I guess cos its a power bank also
I've got a AirPods Pro also. Obviously one cannot compared a $300 unit with the TWS. But the TWS is decent enough for me to use with the PS4. I always had issues connecting automatically my AirPods to the PS4. Had to re-pair most of the time. Thus was looking for a cheap pair to play around with. Well, luckily the TWS solved my problem.
[/url][/IMG]
Crimsom
Hey guys, I'm looking for recommendations for true wireless earbuds for running use.
I've found 2 major models and find it hard to decide between the two: Jabra Elite Active 75t and Jaybird Vista
I think the ambient sound feature on the Jabra Elite active 75t is useful for running while the Jaybird Vista is a little cheaper
Anyone has experience with either and which one do you recommend?
Thanks!
benzene
Thanks!
I am using vista since their release. So far performance wise is very good.
I cant say for Jabra as i havent try it before.
canbedone
I have been using Jabra Elite Active 65, its very good overall, sound, herathrough, durbility, battery life, buttons all are good. I am looking to upgrade to Elite Active 75 wireless charging edition, still waiting for it to release
zhengwen89
I think if looking for cheap and good one can try the Blackdot brand, it looks quite aesthetics also lol i bought it from Shopee during the NDP sale
storm913
For those who got the soundpeats SE 3 and like to use comply tips, can try the Misodiko foam ear tips. I got it from shopee, using the size S, the sound is so so much better and the fitting is also better than the original foam tips.
animeonegai
is it the TWS ones?
gong318
day 2 or using soundpeats truengine 3 se.
switched tips to jvc spiral dots. overall enjoying this pair more than my lypertek tevi I had. this pair is more musical and enjoyable compared to the tevis. It caters to a wider genre of music too.
