DigDub
Cool will check both out thanks!
Edit: after checking both out, they both seem really good, so it's kinda hard to choose. From your experience which sounds better?
It depends on which kind of sound signature you like. Melomania has a warm sound signature and is bassy. Mifo is clear and crisp with forward mids and has lesser bass.
Melsolut
Hi, I just got the Hayley GT1 Plus and I find that the volume is lower than normal. As a comparison, I need to go to 90-100% volume on the GT1 Plus to match the ~70% volume on my Redmi Airdots or Jabra Elite Sport buds.
Tried resetting the GT1 twice but nothing has changed. Anyone else have this problem?
The sound quality is also underwhelming compared to my Airdots.
polowalrus
Bought Haylou GT1 plus on 9.9 for $15 after discounts. Really no complains at this price. Good enough to go exercise with these. Spoil also no heart pain :s13::s13:
bladez87
What discounts? Which seller? I was looking for this as well...
Sent from Xiaomi POCO F2 PRO using GAGT
NahtanojMil
Ooh I see, I guess I'm leaning more towards melomania. Thanks!
Alexz_Hong
it's normal for the volume to be a bit lower though. when jogging i normally have to get to like 90% or so, but as long as don't have to max it and still feel it's not enough, it's good enough for me. Also the QCC3020 implementation can be a bit funky at times. Depending on which side i connect to as master, the same percentage can have slightly different volume output. So maybe you can try using the other side as the master to see if volume is a bit better.
Sound wise it's probably an acquired taste. not very fun or very bass heavy, so some might find it a bit lacking in bass. For me i like it because it doesn't really overdo things, where as a lot of budget TWS just tend to go for the more common v shaped fun sound with more bass and treble. :s13:
polowalrus
From shopee mall. There was a flash sale for 21.99? -3 shop discount and there was a 20% off min spend $50 coupon for electronics cap at 10$.. total 15$
Supposedly have 12mth warranty but I doubt if they will replace if it breaks. Likely to quote user issue thats why break. But then again its only $15. No complains from me
ParkJinYoung
Knn I lost my charging case for my T1X
I wonder if I can just buy the case
Sent from Google PIXEL 2 XL using GAGT
nomoreliaola
For zoom call via tablets, what TRW is best in calls ? Budget 200+-.
Posted from PCWX using Pixel 2
Yua Mikami
sway until lao sai morning hoot 75t evening drop my 75t at ECP... when i realise it I retrace my track and my 75t is nowhere be found... :(:(:(
ParkJinYoung
Anyone know any cheap china earbuds with casing that is fits Fiil T1xs
Yua Mikami
wah heart pain. you dropped the buds or the buds with the case?
Sent from OnePlus GM1910 using GAGT
in case charging while I'm on the phone :(:(:(:(
should have just used the 75t to chat than disconnecting it to directly to the phone...
really regret not using it for call...
freaking $220 burnt ...
