DigDub
Tested sony wf-1000xm3 and jabra elite 75t yesterday. The sony is so much better in terms of sound quality but the size of it is too big for my small ears to make a secure fit. Noise cancellation is amazing but I dont know for you guys, it totally blocks all the surrounding sound which makes me feel very insecure if I'm on the go. The ambient sound doesn't amplify the surrounding too.
Keen to look into samsung galaxy buds live next but the shop doesn't bring in samsung brand. Anyone knows where can we test samsung earbuds?
Stereo can test Samsung earbuds.
Crayon Shinchan
Those using sony wf-1000xm3. what eartip you all using? default?
or got any recommendation? memory foam kind if any?
thank you very much
Computeron
thank you very much
wrong thread bro.. i using other cheap silicon tips.
gong318
thank you very much
tried spin fits cp360, but still prefer default as it sits deeper into the ear canal and has better seal.
any idea why sometimes my sony wf 1000xm3 would disconnect by itself? like it would sometimes switch off and then switch on and connect back even when im beside my phone.
not quite impressed with it considering the price. my mifo o5 has near to flawless connection.
tohchr
Latest version firmware? I got it when newly launch, had connection issues until fedup. Sold it away else it's really a good earbud.
Crayon Shinchan
another issue i facing is my wf 1000xm3 not able to connect to the Sony headphone app. even if my earbud is already connected to my phone.
anyone facing this issue?
need to reset earbud and forget device on phone to reconnect to be able to connect to the phone app.
tohchr
yup. yeah same.. considering if i should sell
If u can bear with frequent disconnection which j can't.. haiz, wasted. Somehow I'm afraid to try other sony tws earbud except for the headphone xm3 which is relatively stable in connections.
tohchr
For this I never encounter. It's still able to connect to the app when the earbud is connected to the phone.
its really great when it doesnt disconnect. some days i go without disconnecting. but when it disconnects, ill be paranoid when it will happen again :s13: which ruins the listening experience
not sure if the app is causing the problem
tohchr
:s13:
Is it u were in a place with lots of wifi or bluetooth connections? It can cause distortion or maybe disconnect.
Nakedtoes
thank you very much
So far the best tips for all IEM is the JVC spiral dot tips... until now i haven find one that can fight the JVC for SQ..;)
tohchr
how does comply foam compare to JVC? I never had JVC before and used comply foam currently. But it's rather expensive for comply foam.
ksksksks
Received fast =:p
Took one working day from local seller
Nakedtoes
I stuff comply foam into my jvc tips. I remove the hard tub of the comply.. Then squeeze the foam tip into the jvc.. Best of both world.
