Got my fill T1 Pro, really sounds good. Initial got the mpow x3, bass was good but was disappointed with the narrow soundstage. Anc on x3 was decent but cannot use anc when running due to it catching wind noise.
Was looking for something similar to my old mifo o5 balanced armature. Then chanced upon T1 Pro with the good reviews and went ahead buying on shopee. But the anc is pretty much useless, almost like no effect. App is in Chinese and the prompts in Chinese. Hopefully future firmware upgrade can improve the anc feature.
nice.. usually at T1 Pro price is it possible to have good ANC?
Coldhead
I think still have to wait till the Chinese brands catch up with the likes of Sony on anc. Basically all the anc on Chinese brands are weak. Heard edifier nb2 is slightly better in anc and was contemplating between edifier n fiil. But the lower price and ipx5 rating of t1pro won.
Henabi
Sometimes I believe "you get what you paid for"
I won't be surprised if China-brand or Chinese-brand TWS earbuds start charging buyers 300, 400 or even 500 in the near future for better features found on brands like Sony, Jabra, Panasonic, bose etc
It's the same with Smartphones. It was only like 3years ago we see china-brand or chinese-brand smartphones charging 500-700 for their flagships. But now, these brands are charging 1K, 1.5K, 2K for their flagships, level with Samsung, Apple
Sent from Henabi virus using GAGT
storm913
Just got a Jabra elite active 75t and set up and updated to latest version for ANC. But realize there's no volume controls on the buds other than voice assistance. Can anyone confirm? Thanks.
Henabi
You press and hold the button on the left earbud to lower volume and press and hold the button on the right earbud to raise the volume.
Anything_Whatever
Depend on what device you paired with ... android or IOS
I’m using voice control on iPad Pro and I control volume by saying.... Siri turn on volume set to 75% :D:D
Jxoppa
Any comments for mpow x3? Looking at this to replace Redmi air dots. Mostly for zoom/webex conference calls and music.
WakaaWakaa
Anyone has both the Blackdot Pro and T1XS? Can advise if the T1XS is a significant upgrade? I have the Blackdot bought recently. But have been tempted by the T1s. However if it’s not gonna be a great upgrade then will just wait till these are spoilt.
katty91
Blackdot is a white label product. Many similar ones in china, u can search mirbuds is the equivalent of blackdot pro just at a lower price tag.
On amazon u can find sellers selling same product with different branding
Wireless Earbuds, Mxland Earbuds 5.0 Bluetooth Earbuds with Charging Case Noise Cancelling Premium Sound Earbuds Wireless for Sport/Travel/Gym/Work (Black) https://www.amazon.com/dp/B0891Z7D38/ref=cm_sw_r_cp_api_i_WoONFbAHNR5VN?_encoding=UTF8&psc=1
Crayon Shinchan
Currently using Sony wf-1000xm3.
Just to ask. What's the best budget earbud for exercising? Best is around $30 range with good sweat resistant. I sweat alot.
Black dot Pro?
Mirbud v9?
Sent from Imperial Chancellor (丞相) of Shu Han using GAGT
ots
Me too. Using the wf-1000xm3 as my main set. And Creative outlier at the gym. But I hiam the bass very weak.wait see if 11/11 got any sale..
Anyone has both the outlier and T1XS. How do they compare?
Crayon Shinchan
Is Outlier good sweat resistant?
ots
Sent from Imperial Chancellor*(丞相) of*Shu Han using GAGT
Yup. IPX5. I also sweat a lot.
If you wanna run with it is not recommended
Posted from PCWX using Rem mm is best waifu
Henabi
Wats the cheapest u guys seen so far for sony 1000mx3 ?
Wf-1000xm3 or
Wh-1000xm3 ??
Wf-1000xm3 so far the lowest I see is around 200 BNIB
Refurbished around 150
Wh-1000xm3 so far lowest is around 280 BNIB
All in shopee
