haikallp
Rocking a Jaybird Vista. Love them so far. Bought during 9.9 sales. After Shopee discount and seller discount, $188 (instead of current market price of $229). Perfect for workouts and running. Jaybird has one of the best earphones app too imo.
bladez87
Posted from PCWX using Pixel 2 XL
PRO better or t1xs?
Sent from Xiaomi POCO F2 PRO using GAGT
ParkJinYoung
Any recommended seller?
I got this from Shopee. Although the seller put fast delivery,local stocks but it took around 10days to ship from china. There's a few from shopee which u can use the 10% shopback
Sent from Google PIXEL 2 XL using GAGT
Pro is tiny as compare t1xs. The case is almost half the size
And personally, I tink the fit is much better.
how much u bought? did you try also the FILL TX1 Pro?
is the BT stable when running? will break connection or white noise?
s3856
Bought my Sennheiser Momentum True Wireless last month but righ earbud suddenly no sound few days ago. Don't notice Sennheiser MT 2 get spoiled so easily.
teckgamer
Hey peeps, looking for recommendation.
I would mainly use the wireless earbuds while working out (Listen to youtube and podcasts) and doing calls from home or on my way to the gym.
Budget is $150 or less.
What I'm looking for:
- Fit on ear (won't come out easily while I lift, some earbuds - tried from Xiaomi and airdots not suitable for this, the fit doesn't snuggle and hold on to your your ears. Huge problem while deadlifting and even bench)
- Microphone quality (Good enough to handle calls while I'm walking outside)
What I found so far:
- Jabra Elite Active 75T is way over the budget. I saw there is a decent discount on Jabra Elite Active 65T that would hit the sweet spot of $150. Anyone has tried lifting with this earbuds (Jabra Elite Active 65T)? Did it come out easily? How's the call quality like?
Or any other recommendation?
ksksksks
65t sound quality and call quality surely ok one
Just the model bit old.
Albedo
I had the 65T active and sold it.
I don't like the fit but this is subjective. Wearing it for anything more than 15min was pretty uncomfortable because the unit is fat and didn't sit well within my ears.
Music quality is good, i liked how deep the bass can be straight out of the box.
IP rating is good too, i can wash them, wear them while riding/jogging without worries.
The deal breaker for me was call quality. I could be standing still on the bus or train, and the other parties would think i am at the beach on a windy day.
Japaneko
Can give the Soundpeats Truengine 3 SE a try. Fit is really well for me and sound's pretty good.<$70 so you can buy 2 and still be within your budget. Got ipx5 rating so can use safely while sweating.
Coldhead
Got my fill T1 Pro, really sounds good. Initial got the mpow x3, bass was good but was disappointed with the narrow soundstage. Anc on x3 was decent but cannot use anc when running due to it catching wind noise.
Was looking for something similar to my old mifo o5 balanced armature. Then chanced upon T1 Pro with the good reviews and went ahead buying on shopee. But the anc is pretty much useless, almost like no effect. App is in Chinese and the prompts in Chinese. Hopefully future firmware upgrade can improve the anc feature.
