FD Trinitron
Hi bros, I'm working at datacenter, it's very noisy inside, need to wear ear defender, wonder if TWS earbud with good noise cancellation can replace the ear defenders? Any recommendation for below $100? or really need to up budget?
davidwong
Not even the best ANS TWS can cancel out the high pitch fan noise
FD Trinitron
Yes those high pitch fan noise is as loud as inside engine room.
I've not owned a single TWS earbud/earphone/headphone, so have no idea. What about Bluetooth Closed-Back Headphones?
DigDub
Air v2 in stores already? Or only can buy online for now?
Coldhead
Any comments on this?
I got the mpow x3, sound stage abit narrow. Anc cannot use for running as it will capture wind sound. I used it for ms teams meeting no major issue quite clear but sometimes gets abit too sharp on the other party till got twitching sound. Not sure if it's the other guy mic or Wat. Batt life so so, about 3 to 4 hrs.
FD Trinitron
Considering between Creative Outlier Air v2 and FIIL 1TXS, use mainly for listening music, ZOOM/TEAM office meeting and no gaming, which TWS is recommended?
tohchr
Have you considered Huawei Freebuds Pro which can connect to 2 devices at the same time and great call quality? I tested it in challenger outlet and after testing, paid for the Pre-order. The call quality as compared to Samsung buds Live is so much louder and clearer even in noisy shopping environment. I brought my buds live to test on the spot using 2 phones.
tomb
got a pair of xelastec in size ML to let go as they are too large for me. no packaging. pm me if interested.
Yua Mikami
sad my earbud now cannot pair both sides... reset also cannot fix... now only can use 1 side at a time :(:(:(
dolphina
Got my T1 pro. It is not supported by the app and weirdly decided to pause my music. Very annoying. Anyone with tips to overcome?
On the other hand, I like the ENC and music quality is better than T1X.
Now toying with idea to get T1XS since it supported by app.
FD Trinitron
Thanks for the recommendation but the price of Huawei Freebuds Pro is x3, about the price range of WF 1000XM3 =:p
ksksksks
English or Chinese voice feedback.
Maybe stick to my t1xs
Really happy with it still.
