dreamaurora
Physically wise I think so. Sound wise according to head-fi they say it's different, with the fiil more neutral while the earfun is more bassy. The earfun does sound pretty bassy.
No leh. I auditioned it at Analogue+ and the sound is definitely on neutral side.
DigDub
Yup, Earfun Free Pro. The one selling at $139. Maybe because i auditioned it side by side with Helm TWS. The sound definitely is closer to Jabra.
Oh I see. The fiil t1 pro is supposed to be even more neutral sounding.
Henabi
Decided to get this
Xiaomi Note10, QCY good enough for low budget, quality is better than the xiaomi TWS.
Thank you , will further monitor if the issues still persists because it's kinda random.
Becomes obvious when at mrt especially near escalator...suddenly silent but music still playing ...
ksksksks
Means same manufacturer already but earfun is quite expensive
I thought free pro is using fiil t1 pro design? Air pro then is using edifier tws2 design? Air pro is also available locally.
I don't have the fiil t1 pro but from scarbir review, t1 pro need the app to enable the volume control and to control the low latency mode. Earfun has these enabled out of the box except don't have skip track backward. Scarbir review also mentioned there's no option to turn the anc off on the fiil? Earfun can turn cycle the anc to off, on or ambient mode. T1 pro has proximity sensor which will auto pause the music when the buds are taken out. Earfun don't have.
Snoweagle
Advise you guys not to buy this leather case if you are using Sony XM3. The magnet in the leather case will drain the charging case. My charging case drop from 100% to 5% overnight just standing by. Waste my money.
I’m using this same case as it’s only $10 from Sony when I purchased my WF-1000XM3. Yesterday after setting it up and charged to 100% around 2pm and only just now checked, then drained to 5%.
Henabi
I compared both 75t and 85t before i decided to go for 85t
Music quality: 85t imo is much better
I tested a few songs
1) “The way I are”.. the various levels of Bass were very clear for 85t even at max vol. on 75t will start to “crack” around 70/80% vol.
This could be due to 85t larger drivers.
85t 12mm vs 75t 6mm
2) “Straight, no chaser” & “Moonlight in Vermont”... the separation of the various instruments were better and clearer on 85t as compared to 75t
Call quality: the clear winner is 85t
I tested various mode of phone calls and data calls in a noisy shopping mall...
Whether its regular phone call, wifi call, Whatsapp call, LINE call, facetime, the audio quality on 85t is way better and clearer
3) ANC
personally 85T is winner
But i still need to put it through a series of real life testing
Crayon Shinchan
Anyone using any $20 range earbud for exercise? Pls recommend. Thanks
Sent from Imperial Chancellor (丞相) of Shu Han using GAGT
Henabi
Sent from Imperial Chancellor*(丞相) of*Shu Han using GAGT
Yes.
L21 pro
Amoi F9 v3
Haylou GT1 pro
you can check out my personal recommendations:
Honeydewz
Is this issue common?
when i'm outside my earbud audio will get distorted only when I'm in a store or handheld my phone the audio won't distort...
justln
Uninstall TraceTogether app if you have it.
Henabi
What’s your model?
Intermittent connection only happen once in a while when i wear my earbuds for jogging and workout
imo i feel that the TraceTogether app is never the issue
justln
What’s your model?
Lots of people will disagree with you, me and my friend personally encounter TT app disrupting BT headsets that went away once TT is uninstalled.
Just a simple look at the Google Playstore review for TT tells you everything.
https://play.google.com/store/apps/details?id=sg.gov.tech.bluetrace&hl=en_IN&showAllReviews=true
Honeydewz
What’s your model?
TaoTronics SoundLiberty 79 and aukey 21 both will get distorted
Tmr i should try see whether it will helps
