Henabi
Lots of people will disagree with you, me and my friend personally encounter TT app disrupting BT headsets that went away once TT is uninstalled.
Just a simple look at the Google Playstore review for TT tells you everything.
https://play.google.com/store/apps/details?id=sg.gov.tech.bluetrace&hl=en_IN&showAllReviews=true
Well... dunno leh...
Before I switched to iphone 12, i was using with Android 8.0... never have any issues with wireless earbuds and TT
My missus was using huawei P40 pro and Oppo reno, no issues too with TT
And these were during Covid-19 times
After switched to iphone 12 mini and ip12 pro max, no issues so far on iOS 14.3
Henabi
ZhugeLiang 諸葛亮;131769781 said:
Cool. U have all 3? All about same quality?
Sent from Imperial Chancellor*(丞相) of*Shu Han using GAGT
Yes i have all three.
Not same.
Music quality: Haylou GT1 pro
Music loudness: Amoi and L21 pro
Haylou GT1 pro sadly is still very soft even at 100%
So, if you like to blast your music really loud, imo haylou GT1 pro not so ideal when i was testing.
Normal phone Call quality: Amoi
Data call quality (Whatsapp, LINE, facetime): Amoi
Zoom, Skype, MS TEAM: all 3 quite equal
Battery life per usage: Amoi, followed by Haylou and then L21 pro
Battery life with charging case: Amoi
BT connection stability: Amoi
Surprisingly Haylou GT1 pro gave me a lot of BT connection intermittent issues whenever i use it for jogging and workout
Gaddy23
How’s the t1 lite? Anyone
Enjoying it so far and way better than my previous soundpeats truedots. The soundstage is especially impressive. The Bluetooth notifications are in Chinese though and there's some intermittent disconnections. Nothing serious.
sajokj
Bought one Soundpeats Sonic and Truengine 3 SE. Got it for 108$ (both)
Both are good, but I would say Sonic is really great compared to Truengine 3 SE
Alexz_Hong
Probably not gonna be a super popular option in the very competitive TWS market, but it's actually quite competent in terms of sound quality and tuning. :s12:
em1812
hpv500
I'm using Spinfits - can't remember which model though. I got them from Stereo - brought the earbuds down to test to find the correct model.
wah, thanks! that time i went to Stereo, they pointed Comply but no stocks, never recommend me Spinfits sia... :s8::s8:
dappermen
is wireless really better than the conventional wired type
can u guys shared is the wired/cable type really not much better than wireless headphones?
appreciate your honest comments pleassseee...
hachi
How about creative outlier air? Having sale now @ $69..
limyeewee
Need recommendation
I'm searching for a while but am unable to find one which fits my requirements. May I know if anyone has any recommendations?
Requirement
1. Supports multipoint
2. USB-C charging
3. Decent quality for call
4. No lag for watch shows
5. Not above SGD$50
