dappermen
Now do u understand why is it so hard to search for?? Cos u wanna it Not above SGD$50 for:
3. Decent quality for call
4. No lag for watch shows
kazuki666
I'm searching for a while but am unable to find one which fits my requirements. May I know if anyone has any recommendations?
Requirement
1. Supports multipoint
2. USB-C charging
5. Not above SGD$50
You can try Google reviews for mpow bit s.
Sent from Xiaomi POCOPHONE F1 using GAGT
osmond19
can u guys shared is the wired/cable type really not much better than wireless headphones?
appreciate your honest comments pleassseee...
i think if the speaker/ driver everything the same... wired is always better than wireless. But with Sony LDAC codec, it can get closed to wired. Of course in theory, good quality wired cable, there is zero loss and lag vs LDAC it is supposed to be high bitrate "lossless".
DigDub
Thanks bro. Any mini review from you? :D
Like the full controls. The inner part is now sculpted which makes for a better fit than the tevi. It allows single earbud use (either L or R) and has no disconnection when putting either earbud into the case. The single earbud that is in use will get a down-mixed L and R channel. I think most recent earbuds which use the realtek chipset are able to have these features and has made much improvement to have an upper hand on qualcomm's single earbud mode implementation.
Sound wise, mids are very natural, not nasal nor artificial. There's not a lot of deep sub bass, bass are mostly mid bass. Highs are crisp and not too forward or sibilant. Haven't tried the mic yet. The ambient mode is average, external sound sounds metallic.
tohchr
Thanks for the mini review! I watched some youtube reviews, they mentioned the connections is very fast! Will make a trip to Jaben this weekends then. :)
DigDub
Yup, the connection is very fast. The earbuds connect once the case is open. It behaves like the earfun free pro in this aspect which also connects very fast. I believe both uses mediatek chipset, impressed by how much mediatek tws chipset has improved without relying on proprietary qualcomm technology.
ksksksks
Levi versus tevi
What’s the difference? :s12:
Lypertek Levi.
DigDub
Levi versus tevi
Tevi has aptx, Levi don't have. Tevi button is on the side, Levi is on top. Tevi has longer battery life. Tevi case is bigger and don't have wireless charging.
Henabi
anyone here using airpods pro? is it worth the price? using the regular airpods now..
If you are an iPhone user, i would definitely recommend upgrading to airpod pro. But if you’re not in a rush...
Rumours airpod pro 2 is coming out
wwh5210
Just a quick note. Please uninstall TraceTogether app if your wireless earbuds disconnected from time to time while moving around outside.
