xenocide
i did not get the 65T in the end. (side note, KrisShop 65T sold out almost same day of availability)
i found a good seal with the PaMu by using different foam tips for L and R.
some generic foam tips i bought previously for the TIN Audio T2.
audioenslave
Manage to give e8 another try.
Wow i’m impressed after using it with the beoplay app and switching out the earbud tips from my shure846.
Seal & isolation is good after that. (Esp with edm & hip-hop music)
Overall im satisfied.
mobiken
I'm actually happy with 65t listening to music but not receive and make call..
doki81
I know some users here have bad experience with the 65T. But i see only less than 10 bros here with issues. Sample size here too small to convice me to not buy it:s13: besides if i were to judge the product on user reviews then there are much more postive reviews about the 65T on the internet(tech sites, amazon customer reviews, youtube reviews)
Or maybe like what some said only some units have specific issues. Im getting mine from amazon us. So fingers crossed
Im also very sick of not being able to plug in my wired earphones while my phone is charging:s13: so right now i really want a true wirelss earphone. Just hope the unit im getting got no issues :s13:
Uppz:o
not here..go read all the comments at jabra facebook page...everytime they post a new 65t post..people start to comment on this issue~
but if u have money to spent to try... i guess this 65t still look quite cute and maybe can only use in door :)
Snoweagle
Now i can let go of my erato verse
I also love my E8 and am using the default tips that came attached to the earbuds, so far so good.
Hmmm seems like your Shure’s tip’s opening is a lot smaller than the B&O’s.
audioenslave
Yea. I couldnt get a good fit with the med size earbuds n complys that came with it. Decided to use shure ones cos they fit snug in the ears.
wizardmao
What eartips are those:s11:
doki81
Thanks. Maybe will try see if i can get one set of those. See if it'll help solve the weird issue i have with the default E8 M tips
have you go try out spinfit tips yet?
PSA: jabra E65t have new f/w update...
Firmware release version: 2.10.0
Release date: May 23, 2018
Solved an issue that could cause distorted audio in left earbud
HearThrough improved and minor fixes.
Solved an issue that could cause un-balanced audio between left and right earbud.
Minor improvements
doki81
By right the Jabra apps will notify us for firmware updates right?
if only you open the app, you will see under the device page has a red dot...that's the indication of new fw update available..
