waterballoon
Personally i will recommend you to consider Buds Air 2 Neo vs Jabra Elite 3
Feel free to check out my review on REALME Buds Air 2 Neo
thank you. how did you get it for so cheap tho?
on amazon Singapore it’s $57 and cheapest I can find is $46 on Lazada. but the Lazada one should be from China which means voice prompts in Chinese? quite confused also, that’s why was looking to Sony/Jabra cos less hassle, haha
ferocity
Creative IT show promos
The newly launched Outlier Pro early bird price 10% off
Outlier air V2 @ $49 not sure if good deal or not
Henabi
I usually compare across multiple platforms
Qoo10, Lazada, Shopee, Amazon, Taobao, Ezbuy, Aliexpress
and see which is the best one after factoring all costs
you will be surprised that sometimes Aliexpress is the cheapest
Sometimes Qoo10, sometimes Lazada
hope that helps :)
waterballoon
hope that helps :)
thanks! maybe i should check out aliexpress too
micshang
Hi, anyone has owned Samsung Buds Pro & Liberty 3 Pro? Can share your experience between this 2 buds? Leaning more towards Samsung Buds Pro as I'm using with Samsung mobile phone.
Any recommended place to test this 2 ear buds?
Many thanks in advance!
Henabi
Usually i got Connect IT to test
since its inside a shopping mall and next to Dian Xiao Er
so it is easy to test out many things like ANC, Call quality in noisy environment
micshang
Thank u very much for your advice.
Will pop over to the store to try it out. Hope they have the 2 models I'm looking for to review.
Doraemon70
Hi,
Doesn't anyone know of a earbuds or airpods kind that has bluetooth multipoint where I can pair 2 mobile phone simultaneously and can use single buds independently. Price range below $200
Been google alot but found limited multipoint earbuds/pods in the market
Jabra elite 7, B&O (both too ex for me)
Anyone can help recommend? Android phone user.
Thank you very much
zhihe1996
Hi,
Thank you very much
Can get Jabra Elite 75T on Amazon for $99. US set.
tohchr
Hi,
Thank you very much
Huawei Freebuds Pro. The multipoint connect is one of the best I had come across.
Launch Price was I think $238. Now u can get it from Huawei Shopee like $178 without any voucher discounts yet.
Henabi
Hi,
Thank you very much
I think the type of Multi-device connection you are asking is currently not available.
I just came across one such Kickstarter campaign, it is called GENKI Waveform.
It comes with two features.
1) Dualstream.
Both earbuds can be connected to two different devices via Bluetooth.
Not only that, it can allow you to stream & chat with two different devices at the same time
Example: Left Earbuds can be connected to Laptop for Zoom, while Right Earbud can be connected to your Phone to listen to music and answer phone calls. All happening at the same time.
2) Charging case as a Bluetooth transmitter
This is similar to LG Tone Free FP9
http://kck.st/3tcOcPE
tohchr
I am connecting left earbuds to iPhone and right earbuds to Android phone.. :ROFLMAO:
Using Sony Linkbuds
Doraemon70
Hi,
Thank you very much
Sorry for the late reply.Thank you all for your recommendations
camile89
Hi all, looking for a pair of earbuds with good bass. budget around 100. need small eartips.
Any recommendations?
