roz_sid
did you try to remove T5 from your BLUETOOTH settings and re-do the pairing?
usually that helps. anyway, this is quite common with QCY app.
yes i remove BLUETOOTH from my iphone setting forget it. but still cldnt connect to app.. any idea how?
DigDub
Impressions later.
Ok so I've charged them up (they came empty) and is able to give some initial impressions now. With the default tips, I find the sound on the default EQ to be too warm and a tad muddled. Changing to a wider bore tip (I used the tips from beats studio buds) and the sound opened up beautifully. Mids becomes crystal clear and picks up a lot of details without sounding artificial or grainy. Highs sound crisp and do not dominate and doesn't sound sibilant. The mid bass is probably a tad too much which makes the sound a tad muddy, I turned down the mid bass using the EQ in the app.
Haven't had a chance to use the mic yet. Pass through sound pretty audible and quite natural. Haven't had a chance to try the ANC yet, passive isolation is pretty good. Haven't had chance to try the wind noise reduction either.
Controls for double tap and triple tap can be customised for both the left and right earbuds in the app, which includes track fwd/back and volume control. Play/pause (single tap on either buds) and hold (left to cycle through the ANC passthrough modes, right to activate voice assistant) cannot be changed. Tapping doesn't produce beeps, so it might be hard to tell how many taps I made.
The buds themselves are on the large size. I find them to be comfortable in my ears. They do protrude, so probably not very good for side sleepers. The case I would say is about medium size, not the smallest, but it's longish, so it's easy to slip in and out of pockets.
It supports AAC and SBC codecs, no aptx or any fancy hi-res codecs. But the sound quality easily beats tws buds which plaster superior codecs and hi-res logos on their boxes. The Noble H-ANC shows why excellent tuning is way more important than just codecs.
Henabi
I think its more of the physical pain & pressure of the earbuds pressing against the ears if the user is wearing full-face helmet
when riding… can off ANC cuz not all ANC earbuds can reduce or remove wind noise.
iteo74
Comfobuds pro buyers, may I know where you buy it from?
I see 2 China sellers Qilmily and Mirako trading for less than 80 whilst the store and ConnectIt selling at 119.
TheOutsider
I ordered from Shopee 1more Shopee Mall w/ 12 months warranty. It was $99 when I bought so I just grabbed those. Now back to $119.
Oh ya disclaimer. It is really quite hard to get it out from the case, if you mind that.
iteo74
Thanks! I went ahead with the Qilmily seller since he's been on laz for 5+yrs. Hopefully all well :)
N0name
is aukey n8 good for calls and travelling music (trains) ?
i am not into the long stem design
using samsung buds not really good
ThinkMe
Samsung Galaxy Buds2 Pro
Graphite
White
Bora Purple
S$328
Henabi
finally I am testing out the Creative Outlier V2 and V3
Huge case... Huge earbuds... Huge sound (Luckily)...
Flying off tomorrow... just nice can test out the V3 ANC feature
messi7
Anyone using Sony Linkbud S?
tried it today and was pleasantly surprised by its sound quality with good bass
ferocity
Been eyeing the Linkbuds S too. Alot of folks here seem to go gaga over XM4 but over at Headfi the general consensus is that the Linkbuds S trumps the XM4 in terms of SQ. Currently the Linkbuds S is selling for USD$148 + USD$7 shipping over at Amazon. This is the cheapst i can find after conversion, compared to other platforms like shopee and lazada.
DigDub
Some
Some pple find the xm4 to be too dark. Linkbuds S sounds brighter which appeals to more pple.
messi7
Nice, I’m considering the linkbuds S and L3P
L3P have glowing reviews but I worry the earbud design wear long ear will pain
