netzach
- Nov 28, 2011
any idea if it's good for work purposes? e.g. teams meeting on laptop
have used V3 for zoom, teams, Google meet, all good.
Read HWZ Forum Rules!
Looking to get a set of Bluetooth earbuds for my dad. He prefers smtg simply and with ANC.
Any recommendations? Budget around 60.
If given a choice between QCY T18 and creative outliner air v3 , which would be a better choice?
Totally agree. Even though I am still preparing my personal full review but i must say that ITs definitely my personal BEST ANC earbuds at under $60Creative outlier V3. have used it for a while personally.
best value for money under $60
Creative app to adjust touch control and EQ settings
active noise reduction and ambience modes.
solid battery life with the huge battery pack case.
best **** I’ve gotten for such a price.
can use immediately without the creative app.
even with the app, the app will auto detect the earbuds and add it into the app.. no need to do anything else
*disclaimer i am not paid by creative to say all these. I bought the earbuds with my own money
Is it possible to adjust touch settings to mute/unmute calls?
Usually I prefer to manually mute my mic, which usually has a separate button for mute/unmute, instead of using touch controls…Is it possible to adjust touch settings to mute/unmute calls?
Indeed XDthis creative v3 is damn tok kong.
top class.
would not hesitate to buy the new versions when it’s out.
Indeed XD
if creative can reduce the case size while maintaining everything else… perfect
Support local mah but not blindly support. Creative is indeed not bad for the price rangeWah how come here so many creative IB
I'm 1 of the first to support their first ever wireless earbuds.Support local mah but not blindly support. Creative is indeed not bad for the price range
I am skeptical.. never had good experience with creative things.. maybe a few months then start giving issues. There are a lot tiong options that are more advanced (e.g. Baseus, Xiaomi..)I'm 1 of the first to support their first ever wireless earbuds.
First right side problem, exchange with them then left side problem
Exchange again, then back to right side problem.
Don't have so much time to always travel to TPY to exchange
So dont wanna use anymore
I had their outlier one before too. 1 side spoil then send in for exchangeI'm 1 of the first to support their first ever wireless earbuds.
