DigDub
Huawei freebuds pro 2. LDAC, planar+dynamic dual driver, devialet.
TheOutsider
I am skeptical.. never had good experience with creative things.. maybe a few months then start giving issues. There are a lot tiong options that are more advanced (e.g. Baseus, Xiaomi..)
+1 Skeptical hence trying to see if anyone can get the mic test done. Went for 1more just 2 months ago. Have to say not the best ergonomics and look but one of the best at picking up my voice so far. Had Elite 85t that costs 3 times more of the 1more yet can't pick up single words I said.
I have Creative Pebble V3 Desktop Type-C speaker I think good for the size and the feature but other than that don't have any other Creative products right now.
Henabi
Outlier V3 mic is better than V2 but if its for basic music listening... it is a very good choice
kena poisoned by you all. see really so good or not. also bought one v2 to keep in office.
Nice :)
Henabi
for outlier V3 earbuds imo... no need to setup SXFI app. Just the creative app can liao.
Henabi
It's the v3 bass heavy? I like bass heavy
V3 bass is very detailed. Not to the point whereby the bass would overpower everything else. The audio tuning for V3 is pretty good.
imo the best way is to test them personally with your fav tracks
netzach
for me personally it’s pretty decent. but heavy or not is relative.
suggest you to go to creative showroom at Jurong to try it out.
aside, I like that the Settinngs for EQ could be configured for the v3 through the creative app.
good feature for an under $60 earbuds.
cheers.
Read HWZ Forum Rules!
DigDub
How is this compared to the version one?
I don't have version one. But probably one of the best sound amongst the ones I've owned. Got one bug though, the in ear detection will revert to on after charging even though I turned it off in the app.
stillgottheblues
Thank you.
I had the version 1. Not sure if this is a worthy upgrade.
DigDub
Thank you.
I think it's a worthy pair of tws buds. LDAC, planar+dynamic dual driver and devialet tuned. All for $268. Other more branded manufacturers would probably charge $400-600 for the same offering.
stillgottheblues
Creative outliner is a good and safe buy for its price. Only thing I dislike is you cannot replace any tips you like, else it'll have problem charging.
CrispyPeddler
trying up the creative outlier v3...its good on phone. flawless connectivity with good sound quality. definitely bang for buck
but...i have issue with connecting to my pc..the connection is super wobbly. anyone encounter this? or its just my pc bluetooth device is bad
TheOutsider
I tend to have more bluetooth issues with other earpiece with my company laptops as well. Not sure why and whether is it WIndows problem or Laptop problem. Sometimes just happily disconnect mid-call and suddenly not hearing anything from the call.
