Hmmmmm where did you fond the pricing?Lol ain’t ht05 half the price of wm05?
Do you experience this intermittent disruption outdoors ?Hi, wanted to check if anyone encountered intermittent "blackout" from your Samsung buds 2 pro ? I am encountering the stuttering a couple of times.
Lazada. Saw Wm05 for like $60-70Hmmmmm where did you fond the pricing?
Ahhhhh maybe QCY official store having discountz.Lazada. Saw Wm05 for like $60-70
Yes I do , especially in crowded placesDo you experience this intermittent disruption outdoors ?
it is a common issue. probably due to eitherYes I do , especially in crowded places
Wow! Can testAnother new release from Creative, the Zen Air Dot. As expected, this is a ultra budget offering. Personally not a fan of such "half open back" design for TWS.
https://sg.creative.com/p/headphones-headsets/creative-zen-air-dot
Creative Zen Air DOT
Creative Zen Air DOT is a true wireless earbuds designed for all-day comfort and perfect as travel companions. Not only are they a palm-sized marvel but they also pack a punch with features such as long battery life of up to 24 hours, Bluetooth® 5.3, IPX4 rating, and more.
sg.creative.com
Yeah....hate this kind of design too. I find them uncomfortable as the fit can be quite wonky for my ears.Woo that's really affordable but personally I dun like the apple airpods design, prefer iem style
Same.earpod style have to fit well to be comfy.
this kind or classic flathead earbud style if it doesn't hurt, you can wear all day. iem the max i can wear also only 1~2hrs, as ear canals feel very stuffy especially when using some eartips like Dunu S&S.
i look forward to what creative can do with the xMEMS drivers... seeing how so far all those that did kinda buang and were prohibitively expensive
No one can help?Looking for recommendations. Budget around 150-200. Anyone can help? Thanks in advance.
What are your needs?No one can help?
Have you tried budget tws around $20? And if so, what improvements are you looking for? If not, can try them firstNo one can help?
Soundcore liberty 4What are your needs?
1) do you need ANC? Yes
2) what kind of music u listen to? Chinese pop
3) gonna wear for workout? Nope
4) just for music or will use for calls too? Both music and call
5) do you need to wear earbuds for long hours? 2 to 3 hrs
I have airpod pro but spoilt already. Any good budget one you will recommend? around 50-70 range range?Have you tried budget tws around $20? And if so, what improvements are you looking for? If not, can try them first
