peaceheart
Wah checking
my airpods 3 years ago also half dead, the left one only works for 5-10 mins now
Due to battery or circuitry? If it's battery, apple is able to replace it right?
Henabi
How old are the airpods?
Bye bye airpods.....
just bought.... airpods pro gen 2 with USB-C...
sigh
Wah checking
my airpods 3 years ago also half dead, the left one only works for 5-10 mins now 🤣
I read that the internal battery inside airpods is super difficult to replace. best to get just get as new one
nowadays many wireless earphones function very good
peaceheart
Any feedback on edifier x3 lite? $20 only....
Or maybe try soundcore a20i... Hmm
Edit: realised there is earlier post on x3 lite and he got it for $14! Think I will get the soundcore... Try something different
ferocity
About an hour ago, Soundcore Liberty 4 NC was going for ard $74 on shopee flash deal after seller and site coupon. Probably the best sub $100 tws in terms of features and sound currently in the market.
darr
https://www.amazon.sg/Edifier-W240T...qid=1696937469&sprefix=edifier,aps,314&sr=8-3
Edifier W240TN Prime members deal $52. I think is cheapest I see , taobao TWS Pro equivalent is $55.
EDIT: Flash prime code BIGDEAL5 $50-5....so it becomes $47....tempting....alas better don't lol.
Also there's Yamaha TWS-E3B $43. Seems good reviews though old model. I think Edifier X3/X3 Lite still among the best price for cheap buds.
darr
Unlikely can get at that low $14 price again. Other than the seller $5, it was stacked with 156coins=$1.56 and additional $25-5 lazada platform voucher that suddenly appeared in my account at 10pm during 9.9.
peaceheart
$14 is best price ever liao. $20 is gd price. I got mine for $32? 3 yrs ago.... Micro USB port somemore lol. Still working.... So want to buy new tws also cannot since I have another 2 pairs of tws, total 3 pairs
darr
Anyway you already have the X3. Lite is exact same design and sound is literal same when non-APTX, so you lose APTX and gain app control, but lag is somewhat better. Personally you should try other models, for example W240TN. With ANC for $47 only lol.
ferocity
I posted before regarding the Edifier W240TN. Just take note about the drawbacks with this model
Love pretty much everything about the Edifier W240TN. Decent sound quality, small and compact charging case, actual physical buttons for controls which i have always preferred over finnicky touch controls.
But there is one con to this pair of TWS which i find to be somewhat of a deal breaker. You cannot customize the controls on each earbud individually since the same setting applies to BOTH sides of the earbuds. This means you are limited to 4 functions since you can only do single/double/triple press or press and hold. So lets say if i configure them to do volume up/down + next/previous track, i lose out on ANC control and would have to use the app if i want to change the ANC mode.
animeonegai
Any pro can recommend a good wireless earbuds for 200 below with a good batt life of above 8 hrs. Replacing soundcore liberty 3 pro
Alyeska
Am curious, is there any wireless earphones that are dual BA drivers?
Tried the supposdedly best one this year by Sony WF-1005XM5 but am just disappointed with how it sounds.
Just got myself a P8P but am using a IM02 previously on my HW Mate 20 with 3.5mm jack.
Anything that sounds remotely close?
