toastiee
AZ80 was on sale yesterday down from $469.
animeonegai
I feel liberty 4 NC not high in battery... A40 seem like better. Any discounts on this?
Henabi
afaik, earbuds with better ANC will usually have slightly shorter battery life, compared to those with lesser ANC
in the end, its down to the core features you want in a pair of wireless earbuds.
if you want better sound quality + better ANC + more compact size = slightly lower battery life.
if you want good sound + good anc + good battery life = bigger earbuds size, such as Creative outlier Pro
in the world of tech products, i have learnt to Give some and take some…
So far, there is no perfect earbuds yet.
Gadgetfreakloh
I found my perfect pair of buds after going through more than 40 pairs through the years. It is the Gemini 2.
Gadgetfreakloh
40. Pairs!!!!! Wow
Still have over 20 pairs now consider having sold and dispose some due to kaput. I have the discount code 20% off for Gemini 2 that is given to Gemini 1 owners. Did not use it as i got the 2 first before they launch the upgrade program.
Anyone wants the code can PM me.
Squeezer
Anyone had nokia earphones?
Bought a pair recently - nokia true wireless 3110 and the battery was crap. Lasted 2 songs only and went flat despite charging it full for 3 hours.
Went back to changed another pair and the outcome was the same.
So disappointed with their QC.
luei74
Saw it at popular few weeks ago, wanna check with gurus here about the performance.....seems bad quality product
luei74
Anyone got a good wireless earbuds with good and clear mic to recommend? Budget from $60 - $100.
cryn79
Hi all
Current earpiece - SoundPEATS for True Air Bluetooth Earbuds True Wireless Touch Control Earphones 30Hrs Playtime CVC Noise
As per abv is my current ear piece, which I have been using since 2020. The ear piece does not charge properly already. Therefore looking to buy a new one on 11 Nov.
Can I pls seek recommendations from the below list or other brands?
Requirements:
a) Clam shell type ear piece ( not ear buds)
b ) Budget: up to $100
c) Purpose: Listen to music and online radio
d) Not using for running
As per below are the shortlisted ear piece.
1. Soundpeats for TrueAir2
2. Soundpeats Air3 Deluxe HS
3. Soundpeats Air4 Lite
4. Soundpeats Air3 Wireless Bluetooth V5.3
Thanks!
